Will I need a longer chain?
sd5500
by sd5500
My force 1 cross bike currently has a 40 and 11-36. I'm considering putting on a 44 up front for gravel rides. Will that require a chain longer than I currently have installed?
ironhayden08
by ironhayden08
Likely yes. For CX season, I run 38, 40 and 42T chainrings with an 11-32 cassette. I can't run the same length chain for the 38 and 42.
Marin
by Marin
ironhayden08 wrote:I can't run the same length chain for the 38 and 42.
I'm pretty sure you can use a chain that works with 42t also with a 38t.
SRAM 1x mechs will do that, and all other rear derailleurs are 2x and will do a much bigger difference too.
sd5500
by sd5500
I'll size up a new chain and let you all know.
ooo
by ooo
425 cx chainstay + 40 front + 36 rear = 53.4 chain length, rounded up to 54
425 cx chainstay + 44 front + 36 rear = 54.4 chain length, rounded up to 55
