XC MTB 29 inch wheels for a gravel bike build
mattr
by mattr
MikeD wrote:Mattr, why do you use hookless rims? What are the advantages for gravel or road use over hooked rims?
Who said i use hookless rims for any specific reason? I just use whatever fits my requirements at the time. Hookless Vs hooked makes no difference with Gravel, CX or MTB sized tyres, at suitable pressures.
If you want to run gravel/large volume tyres at significant pressures. You might need to add requirements to your purchase, like hooked rims.
But the op is asking for advice about MTB rims for gravel/cx use, which would suggest larger tyres at suitable pressures.
jeroenfl
by jeroenfl
I have a set of mavic crossmax slr 29ers with bruce gordon's rock 'n' roads for my rlt9 steel.
I run them tubeless, but hit a rock or root real hard (singletrack dowhill) and they'll burp.
Also use the pacenti cl25 which also is an xc rim, i think.
So still looking for a set of real tough tubeless tyres for downhill and really rough surfaces.
Besides that, i have a few sets with tubulars i built with shimano xt MTB hubs (cheap).
Actually, my favorite wheels are these XT's with ambrosio nemesis rims and chicane tubs (have tubeless clement las tubulars ready to replace them - chicanes are fragile). Looking forward to Vittoria's new Terreno dry.
leicaman
by leicaman
That's for all the info guys. I went with the mavic xc421 rims on hope hubs. I've ordered 38mm schwalbe g-one tyres (although I'm not actually sure if they are 38mm or 40mm as it isn't clear in the description, but either width will be fine) and will be running them tubeless with the mavic rim strips most probably around 35psi so I can't foresee any problems with the hookless rims.
emotive
by emotive
mattr wrote:I don't know of any road rims that are hookless. That should tell you something. (Someone is sure to come out of the woodwork and mention one though :-))
With the move to road disc, wider tyres, and now wider wheels are the trend. Aside from Enve, the new Roval CLX 50 from Specilaized are also Hookless. I purchased a set of Light Bicycle RR36C02 hookless wheels for road use, 22C inner, 28mm outer. Wheels are rated to 80psi, but I've never run tyres that hard since i moved from 25 to 28C tyres. I'm running 28C Compass Tyres at 45 to 60psi depending on if it is a commute, gravel, or fast group road ride. 3000km done in 6 months, no issues, plenty of comfort, speed, and grip.
euka
by euka
Lelandjt wrote:For carbon MTB rims you need to ask the manufacturer the max pressure rating. Whether it's because they're hookless or due to the thickness of the rim bed most don't authorize over 40psi.
Also the force pulling the rim apart depends on tire width and pressure: https://www.eastoncycling.com/media/Eas ... essure.pdf
the_marsbar
by the_marsbar
MikeD wrote:Very few people are using tubeless road tires because basically they suck. 80 psi is too low for me.
You do realize you're in the CX section, right?
I use a Notubes Valor on my CX bike, and they've been great so far. I don't feel any major differences between them and the tubular setup that I was running with my previous bike.
MikeD
by MikeD
28mm tires at 45-60 psi is ridiculously low pressure. You must be a light rider. To run that low a pressure risks pinch flatting, rim damage, crappy cornering, and high rolling resistance. Tires on my wheels measure 27.5mm and I run 80 front, 95 rear and I weigh 195 lbs. This is the recommended pressure from the Frank Berto curves for a 15% tire drop.
CallumRD1
by CallumRD1
I'm 150 lbs (68kg) and I run 28mm tires at 60psi all day. There is absolutely no squirm when cornering hard, I've never pinch flatted even though I have a propensity for jumping up and down curbs on my commute, and the rolling resistance is negligibly higher than at 80 psi. They are very comfortable at that pressure and I notice a distinct increase in harshness when inflating them to more than 60 psi. I have tried riding them at 45-50 psi but I found that too low for me and thought that they felt sluggish while cornering. Note that I'm running these tires on wheels with a 19mm internal width, so there is little to no lightbulb effect. When I ran 28mm tires on a very narrow set of rims I found that I needed slightly higher pressures to maintain good feel while cornering.
simoncx
by simoncx
I run Easton ea90xc wheels on my disc cx bike with either cross or 25-28 road tires without any problems, just make sure the cassette body will take a 11 spd road cassette because some mtb wheels will not fit a road cassette. Hope hubs can be used with mtb and road cassette if that's what you go with.
MikeD
by MikeD
No, it isn't. It's Cyclocross / Gravel / Touring. The OP asked about a gravel bike wheel build, not CX. CX courses bear little resemblance to gravel road riding. I would say that people that own a gravel bike ride it on pavement a lot too.
ms6073
by ms6073
Probably overkill, but I have enjoyed using a first gen Enve M60 wheelset purchased off Ebay and paired with a set of Schwalbe G One tubeless tires for gravel/all-conditions riding.
emotive
by emotive
82kg
i've done 14,000km on 28mm tyres and haven't had a pinch flat or rim damage yet. I can descend most segments in the top 10% on Strava, having confidence in the level of tyre grip helps here. The rolling resistance penalty for 60psi vs 80psi is about 4w per tyre, according to https://www.bicyclerollingresistance.co ... i-23-25-28. I'll happily pay that price for better cornering and ride quality.
my 28mm Conti GP4000 measured 32mm, and my current Compass 28mm tyres measure 30mm on my 22C (28mm outer width) wheels. Wide tyres work better with wide wheels to support them.
simplemind
by simplemind
Don't overlook the I9 wheelsets. Particularly the UL235.
SpeedyChix
by SpeedyChix
Using Bontager XXX TLR mtb wheels for my gravel setup. I don't run pressures above 40psi on them.
adrenaline junkie
justaute
by justaute
FWIW...I run IRC RBCC 28mm tubeless (28mm measured) on my road bike and usually run ~65-70 psi front and ~75-80 psi rear. I weigh 93-95kg and have a muscular built; and, am hopeful will be 90kg or so in the not-too-distant future. Trying to lose some fat and muscle...not easy. :)
I push my bike hard in cornering (mtb/BMX background) and the tires/handling are fine so far.
