1x crankset w/ power
stuh
by stuh
Hey all
Looking for advice/recommendations for a crankset for my CX race bike. Currently running a Quark Riken with SRAM carbon arms and a Raceface 42t nw chainring. Functionally it is fine, but this is weight weenies.... IIRC this setup with the SRAM team BB was pushing 800g
Requirements:
  • Power measurement - ok with left leg measurement but not crazy about it
  • 68mm spindle No BB30 etc
  • an option for direct attached chainring a la wolftooth preferred
Any ideas?
glam2deaf
by glam2deaf
If you're wanting to run a direct chaining then anything spider based is out the window. Probably your best option is to go to a Stages/4iiii
Marin
by Marin
Force crank with stages and direct mount. That's what I'm running.
LouisN
by LouisN
A P2M Rotor crankset mounted with 1X setup would do the trick, and pretty light also. Even with a 30mm axle, with a BSA30 BB. The Rotor Inpower is advertised at 525g ( without battery or chainring).
I'll run my DA 9000 left crank arm with a 4iii Precision PM on the CX bike this fall. Will probably just swich the left arm, and istall my old 7800 crankset with a single Narrow Wide ring. Not the lightest but easy swap, and functional.
Louis :)
tpiuhis
by tpiuhis
Quarq XX1 Eagle
grilledcheese
by grilledcheese
I use Force 1 with P2M type S. Good function, easy to install/change battery, relatively affordable, no issues with chainline.
hmai18
by hmai18
Is the Force P2M a BB30 or GXP interface?
mattyNor
by mattyNor
New Easton crank as well, I'm running the non power version on my cx/gravel ring and it's amazing!!
LeDuke
by LeDuke
Easton/RaceFace​ spindle with Hollowgram arms and Garbaruk single ring.
Garbaruk has the best chain retention of any ring I've used.
Sent from my XT1585 using Tapatalk
stuh
by stuh
LeDuke wrote:Easton/RaceFace​ spindle with Hollowgram arms and Garbaruk single ring.
That'll fit in a standard English BB? Any chainline or Q issues?
stuh
by stuh
Anyone have experience with the Easton EC90SL?looks like it'd be the lightest to fit the bill and not too expensive to boot
LeDuke
by LeDuke
It will work with a BSA30 type BB.
Chainline will depend on what ring you get, and the frame. Plenty of offset chainrings these days.
DDX
by DDX
Any advise for 1x11 crank when I want a 42 tooth chainring ?
I was looking at the Quarq XX1 Eagle crank but it looks like 38 is the maximum I can run with this crank.
I prefer a powermeter with left/right option.
stuh
by stuh
If you want L/R your basically just looking at quarq and p2max. Which are about ~200g each. That puts you in the 700g range. If you can work with Hollowgrams SISL2 with a p2m should be pretty light
