Campagnolo 1x11 Question
glam2deaf
by glam2deaf
For a new project I'm looking at running it 1x11 with a SR group set I have lying around. I'll be running 38t on the front, but the rear is where I'm confused.
The bike will be a go anywhere ride, so would like to run the widest possible cassette. Thinking Shimano 11-40/42. There shouldn't be too much trouble setting it up, but I'm going to need a fairly long chain to take up the slack.
I've seen the Potenza medium cage swap done to run a 2x11 11-32 go guessing this will work, or am I right in thinking an Athena triple RD will do the same trick?
Also as a follow up, what would be the largest cassette range I could run on a standard SR RD?
Marin
by Marin
No way will any Campy RD shift a 42t cassette.
38 / 11-32 is actually a decent 1x setup, but probably too hard for longer climbs where you want lower than 1:1.
AJS914
by AJS914
I'm going to throw this out there - I don't like the 1x setup on my gravel bike. I wish it was 2x and if I was rebuilding it with Campagnolo I'd try a 50/34 with the Potenza rear derailleur and the 32 cassette. That still might be enough gear for steep off-road climbs. It obviously would depend on your local geography.
duende
by duende
I run a 2X 50/34 with an 11-32 cassette on Chorus. SR could probably do the same. Also was considering a 1x set-up initially. But my road bike legs are just too accustomed to smaller incremental gearing shifts, so I chickened out and passed. Still want to try it someday.
I read somewhere on another forum, that a member replaced the cage on his rear derailluer with the potenza long cage... and that seemed to work well for him. Don't know the max gear he can have though.
AJS914
by AJS914
Another option may be a Roadlink extender:
http://www.wolftoothcomponents.com/products/roadlink
rheosibal
by rheosibal
Running 1x11, 38 front, 11-32 Rear. No issues at all. If there are any changes, I'd probably go for a wolf tooth road link.
grover
by grover
What about Jtek Shiftmate 7
http://www.jtekengineering.com/shiftmate/shiftmate-7/
This will make your Campagnolo SR 11 Speed shifters shift a Shimano 10 Speed MTB derailleur perfectly across any 11 speed cassette. That derailleur also has a clutch which will improve chain retention.
There is no solution that mates Campagnolo 11 speed shifters to a SRAM or Shimano 11 speed mountain bike derailleur.
The 10 speed derailleur is meant to only shift up to a 36 tooth cog. But plenty of people got them working with a 40 or 42 tooth cassette. I'd stick to 40 to be safe. Combined with a 38 or 40 ring that sounds great.
Personally, I'd probably just run the groupset as a double with 34/46 rings and an 11-29 cassette.
glam2deaf
by glam2deaf
Hmmm, some good thoughts, figured it would be a stretch to go above a 32. There isn't much I encounter that I can't go up in 39/28, so 38/32 should be more than enough.
Currently wanting to stick with 1x as I'm using a MTB srm for the bike with 120 and 80 bcd, so double rings are a bit unnecessary.
graeme_f_k
Shop Owner / Manufacturer
by graeme_f_k
glam2deaf wrote:Hmmm, some good thoughts, figured it would be a stretch to go above a 32. There isn't much I encounter that I can't go up in 39/28, so 38/32 should be more than enough.
If you are running a SR with a 32 (and you might get away with it 1x on along hanger) you are outside the design spec for largest rear sprocket but then by running 1 x on a 38 in some ways you are a bit off-reservation anyway!
You may lose a bit of accuracy in the middle of the cassette. If it's 2015+ rather than pre 2015, the accuracy loss will be much less as the Embrace system will bring to top jockey up and forward a bit as you shift towards the middle and smaller sprockets & you have more freedom to play with chain length to optimise that, too, in a 1 x system. 2015+ RDs also give you more options & range as far as B-Screw / H-Screw adjsutments are concerned, to optimise top jockey vs cassette position.
J-Tek x Shimano / 10s - it's an option but depends what is meant by "shifts perfectly" - I'd say "shifts acceptably". All the J-Tek devices to is apply a linear modification to cable recovery vs mech movement. The problem is that Shimano cassettes and Campagnolo cassettes have two different approaches to sprocket spacing and that messes with really accurate shifting when RD & lever are intermixed. Some users notice, some don't.
glam2deaf
by glam2deaf
graeme_f_k wrote:
Perfect thank you, this is the sort of answer I was hoping for. Might give it a go, however XT Di2 seems like it's going to suit my original plan.
