Widest Gravel tire on CAADX (Disk)
Crankycolnago
by Crankycolnago
Whats the widest tire you have been able to fit in a CAADX disk ? I know they come stock with 35 I was wondering if anyone has gone wider and if so what tubeless tires are they ? Wheelset is a set of enve XC ..
rasmussloth
by rasmussloth
Which generation CAADX?
wheelzqc
by wheelzqc
I was able to fit and ride MSO 40's with my CAADX. Tighter behind.
RyanH
by RyanH
Calipers to the rear chainstay on the 2016 model shows the width at 45mm. In dry, 40mm actual is probably fine.
Strava
wheelsONfire
by wheelsONfire
The wider rims you'll use, the more the tire swell out.
If you can fit a 40mm tire on a rim 17-19mm internally, maybe same tire come out too large on a rim 21-22mm internally.
Bikes:
Ax Lightness Vial EVO D
Paduano Racing Fidia
Open *UP*
