Best cables for cross
airpoppoff
by airpoppoff
I pretty much end up replacing these cables almost every 300 miles on my bike mostly cause the RD starts hanging (Lots of mud and dirt, wet loose gravel SRAM Red22). Looking at the jagwire sealed kit, do you guys have any opinions?
mattr
by mattr
I just swapped regularly.
Used to unhook the outers to move them around, clean and oil every time the bike was cleaned. (Gear and brake)
Then swap gear inners after maybe 6-8 races. Swap the lot (inners, outers, tape, brake cables) after another 6-8.
Maybe do 24 races in a season.
Only time I tried sealed (gore iirc) they lasted about a dozen races. Then pretty much everything needed swapping.
Ended up costing me more than my usual routine. (Mostly top end shimano cables)
MikeD
by MikeD
I have those Jagwire sealed cables on my road bike and mountain bike. They are great. No issues after 2+ years.
Tomstr
by Tomstr
I'd recommend the sealed system of Gore too. Jagwire is nice as well but needs a bit more work.
On my Idworx I have a fully closed system by using an outer cable all the way from the shifter to the derailleur. This is actually a very inexpensive option if you can make your frame fit it. A decent outer cable and something like a dura-ace innercable will work for ages. Especially if you put those little rubbers at the end. (yes)
Ride it like you stole it
jfranci3
by jfranci3
Shimano's poly system has decent scrappers, is probably the best performing, and cheapest.
Tomstr
by Tomstr
Do you have a link for them? They are essential in cross and gravel.
mattr
by mattr
https://www.rosebikes.co.uk/article/shi ... /aid:39971
I've got some sat in my basket, waiting for the next order.
jfranci3
by jfranci3
Tomstr wrote:Do you have a link for them? They are essential in cross and gravel.
I think any 11sp / duraace / ultegra / xtr cable set
http://www.jensonusa.com/Shimano-Ultegr ... -Cable-Set
Note the tip on the poly sets (above) which has an ID the same as the cable's OD.
MTB guys put these up there close with the Gores. Shimanos shift better overall and are easier to install on the frame. Gore if you are in the mud/powerwash apocalypse.
http://singletrackworld.com/forum/topic ... tie-things
MikeD
by MikeD
Gore RideOn cables haven't been made since December 2012 http://www.rideoncables.com/en_us/
