Tubeless cyclocross tires om tubeless MTB rims...?
rasmussloth
by rasmussloth
Hi
I bought some DT Swiss XR 331 rims (MTB) and I am having problems getting them to work with my Specialized Terra Pro 2bliss cyclocross tires.
Shouldn't MTB tubeless and cyclocross tubeless work together?
mattr
by mattr
I've done ztr crest tubelessly with vittoria cx (non tubeless)
The bead was very very tight on the rim and took some effort/pressure to seat.
How tight was your tyre on the rim? If it's too tight it might be difficult to seat.
stoney
by stoney
I've ridden and raced Specialized Terra Pro 2bliss, Specialized Tracer Pro 2bliss, and Maxxis Mud Wrestler TR CX tires with no problems on American Classic 29 tubeless wheels while weighing 80kg. They were also easy to mount up and inflate.
rasmussloth
by rasmussloth
Thanks, @stoney.
I will continue in my search for success with this combo.
mtbstuff
by mtbstuff
rasmussloth wrote:Hi
It might be helpful to say WHAT the problem is....don't you think?
rasmussloth
by rasmussloth
Seating the tire
mattr
by mattr
mattr wrote:How tight was your tyre on the rim? If it's too tight it might be difficult to seat.
:wink:
Even with the non-tubeless tyres it took some pressure to ping them onto the rim. Needed some lubricant and about 4 bar IIRC.
Tubeless beads are stiffer and (usually) tighter.
AdyM
by AdyM
Some times an extra layer of tubeless tape can help, just ever so slightly eases the transition to ping onto the bead. Soapy water is also your friend!
spookyload
by spookyload
When I have a tire that won't seat, I install it with soapy water and a tube. Let is sit overnight, the take the tube out by only breaking one side of the bead. If air only leaks out of one side, it stands a better chance.
