Cannondale Slate - anybody else excited?
FreaK
by FreaK
what's the BB height with those wheels and tyres?
Also, how much of a comfort hit have you taken?
it's actually possible to come to the conclusion even before realising it makes no sense at all
tymon_tm
Marin
by Marin
FreaK wrote:what's the BB height with those wheels and tyres?
700x23 has the same diameter as 650bx42 so the BB height will be the same as before.
jakkel
by jakkel
BB is the same as before. No comfort loss.
2004 Cannondale F600SL Sobe
2012 Cannondale SS EVO HM SRAM Red
2013 Cannondale F29 carbon2
2017 Cannondale Slate Apex
nunokas
by nunokas
New wheels :mrgreen:
And new weight.
omniviper
by omniviper
Not sure if anyone saw this, but here's an 18lb slate.
http://www.gravelcyclist.com/bicycle-te ... ed-sports/
Also, from a purely monetary point of view, does anyone think the up in componentry of the 2016 slate ultegra worth the extra cost vs the 2016 slate 105? Thinking of getting one. Ive read this thread from start to finish and it may have been the tipping point in getting one. This is coming from a long line of cannondale Caads, Evos, and Trails. I just want one bike now.
tomatoe
by tomatoe
So 18lb = ~8.16kg?
My force 1 slate is close to that weight and spent less money from RRP + mods.
Why did they downgrade shifting and braking performance by that much for some odd grams?
Gravelbikes in general have the traction to benefit from powerful brakes, i find it insane to downgrade to mechanical from hydraulic because of weight savings.
Lelandjt
by Lelandjt
tomatoe wrote:
Fri Feb 23, 2018 8:39 pm
So 18lb = ~8.16kg?
There are several reasons to choose cable discs over hydraulic and I'd argue that the brakes on that bike are quite powerful and have a good feel.
tomatoe
by tomatoe
Name a few.
A beginner can install a set of mechanical brakes. Around 100grams lighter.
Rest are negatives.
Berserker26
by Berserker26
tomatoe wrote:
Sat Feb 24, 2018 4:16 pm
Name a few.
There aren't any. 100g saving vs better brake feel, better modulation, more powerful stopping, I'd even argue less maintenance - no cable friction etc...
To each there own, but downgrading to mech brakes is stupid.
Cannondale Slate Ultegra
Trek Fuel EX8
Marin Pine Mountain 1
Retired bikes
Fuji Cross 1.3
Fuji Absolute 3.0
Lelandjt
by Lelandjt
No sticky pistons, no bleeding, easier to set pad/rotor clearance and get both pads to contact at the same time, smaller levers, no heat limitations. Also, I don't think the feel of a good cable setup is significantly different than hydraulic.
I'm not saying cable is better than hydraulic but I'm saying it's not worse and a definitive downgrade, just different with different pluses and minuses. I bet the owner of that bike prefers his brakes to yours.
tomatoe
by tomatoe
Mechanical disc brakes can overheat rotors to a bitching shade of rainbow just as easy if not easyer.
Less mass to distribute the heat away. Brake fuild boiling point on bicycle brakes is rarely any sort of issue apart from downhill racing.
I dont agree with better pad and rotor adjustment at all. One in ten mechanical brakes actually push the pad straight or let the pads sit straight.
Facing the mounts wont help. Sticky piston's is a SRAM guide thing or skipped the annual piston lubing.
Roadbike shifter's cable pull ratio never worked well with mechanical disc brakes. Minor wear to cable housing and pads -> no brakes.
stockae92
by stockae92
I think for a beginner, setting up a cable disc brake is easier, cause you have shorten the cable without bleeding the system if you are doing DIY.
I think they are "good enough" for some (if not most), but no question hydraulic has better feel, power and modulation. (at least for the ones that I tried)
stormur
by stormur
Road hydro shifters look is unacceptable. It's a pure crime against beauty of the bike. And it's not matter of "taste". Thing is objectively ugly. That single reason is enough to go mechanical ( if one must have disc brakes, which is another crime against pure beauty of the road bike ) :mrgreen:
Mark Twain
hoburgen
by hoburgen
Does anyone know of a 44 tooth oval chainring for Cannondale direct mount (i.e. for my Slate Force 1)?
cerro
by cerro
Garbaruk?
/jonas l
