so what are the lightest cx disc bikes ? (specs and pics)
kfreytag
by kfreytag
Brand new build. Santa Cruz Stigmata @ 16.98lbs / 7.7kg. It's a great-riding bike.
Santa Cruz Stigmata CC in 54cm
Shimano R685 Mechanical Hydro to R785 brakes
Dura Ace 9000 F/R Derailleurs
Ultegra 11/32 Cassette
ENVE post, stem, bars, and Garmin mount
ENVE M50 wheels built on DT Swiss 180 Ceramic Centerlock Hubs
IceTech Rotors - 160mm front / 140mm rear
Vittoria Open Pave 27mm (running on the road right now)
Shimano XTR Race pedals
Fi:zik Tundra 00 Saddle
Campagnolo CX11 36/46 Crankset
Lizard Skin 2.5mm tape
Easy weight loss:
Cut the post (it's LONG)
Cut the headtube
Expensive Weightloss:
Go tubular for CX wheels
Go Di2 (I prefer it anyway)
Lighter pedals (XTR == ~300g)
Life's too short to ride clinchers.
Current:
Parlee Z-Zero ISP
Past:
Ridley X-Fire Disc
elmar schrauth
by elmar schrauth
7,2-7,5 Kilo depending on Wheelset and Tires
These are the heavier ones.
Giant Tcx Advaced, Size Large
Syntace Handlebar
Giant Post and Stem
Wheels Tune Price-Princess, Crossladen Carbon Rims
FMB Tires
Carbon Thru-Axle
Rotor Cranks 177,5-mono
Sram Red Disc, Shifter, Derailleur,
PinaRene
by PinaRene
rasmussloth
by rasmussloth
Nice bike but this thread is for disc brakes...
jcrr
by jcrr
I agree. Though, it does allow a quick comparison on how the tcx frames have changed. :)
@elmar schrauth- nice bike, mate! I'm curious if you weighed the frame + fork before you built it up, as well as the weight of that wheelset. I would like to hear your opinions on the Tune hubs and how much upkeep they require...
JC
"If it ain't broken, it could be lighter"
basurper
by basurper
Does anyone know the weight of of BMC grandfondo gf 02 alu's frame+fork?
http://www.bmc-switzerland.com/us-en/bi ... _disc-105/
Sent from my SM-N9208 using Tapatalk
stormur
by stormur
1700g-ish with der hanger, bottle cage bolts, without sp clamp & headset; for size 51
Mark Twain
basurper
by basurper
stormur wrote:1700g-ish with der hanger, bottle cage bolts, without sp clamp & headset; for size 51
Thanks Stormur.
How about BH RX team disc 2014:
-how much the frameset+fork's weight?
-is it capable to use 700x38c?
Bream
by Bream
And finally my answer; some were rather close :D
stormur
by stormur
Thanks Stormur.
Frame is 1100g for L ( 56cm TT ) , fork 480g ( if memory serves well ). Somewhere I found 950g for size S... but not my measurement.
On front : no issues , rear... I don't think so. Max I rode was 35mm measured and space around was like on limit of "reasonable" to clear dirt.
Note : BH RX "dual" ( disc/canti : 2 dropouts ) has.. "weird" geometry. I bought Wilier because M was to small , L was to big for me. Frame has quite long reach with low head tube. @ my age and riding style : to racy, to agressive. Caad/ Supersix type of geometry if i have to compare to something. But on road some "detorietation" from perfect geo can be compensated, in CX surface will tell you immediately that something went wrong ;)
That was "minus". Pluses : extremely good build quality & accuracy. Same I found on Pina and Neilpryde only. No decals : everything is painted. Visible CF : nothing hidden : you can see layup of fiber ( big plus for me ) - and it's not "decorative". Easy cable routing ( cables, not housing ! ) . Last, not least : frame is real monocoque : molded in 1 piece, same fork ( they use some fancy tech for compression from inside layup ) .
Mark Twain
basurper
by basurper
Thanks for the detailed information.
So the right cyclo frame for ww is the BH rx team. Except for the addict cx 10 which is said to be lighter but I don't see the real weight post yet.
But for convinience IMHO the frame should have TA wheel for easier tire change. So it goes to addict cx 10 or Ridley X-Trail.
As for the wheel is it ok to use ZTR 29 Race Gold (1300ish) 135mm?
Ekorre
by Ekorre
Here is my new steed.
Trek Boone
Bontrager Aelous 3 disc wheels
Schwalbe Racing Ralph 32mm tubs
Bontrager RXL 110mm stem
Zipp SL 40 cm handlebar
Bontrager Serano RL saddle
Sram Force CX1 groupset with long cage RD and 10-42 cassette
Quarq Red crankset with 40t chainring
XTR Pedals
7.6 kg
kimsinu
by kimsinu
I recall seeing an alternative version of the TRP Hy/Rd recently but i didn't bookmark the link. They were lighter, cheaper and I believe that the reviews said they didn't have some of the set up complications that the Hy/Rd suffers from.
bmCube
by bmCube
I think you're looking for juin tech r1.
