Dura Ace 9000 - ETA late 2012/early 2013
Guerdi
by Guerdi
Even if totally OT, keep those old school DA pics coming :thumbup:
HammerTime2
by HammerTime2
No, those are new school. 7400 is New Dura Ace after all. Old school would be Dura Ace AX 7300 and previous.
Dyna Drive
and all that jazz.
Oh yeah, A is for Aero. What's old is new, and that sort of thing.
baldkingpin
by baldkingpin
Madcow wrote (back on p.24, 6/1/12) re: 7900 10spd. rear wheel compatibility with 9000:
"Nothing definitive yet. Wayne has been riding a 10 speed cassette with the new group for a few months and doesn't seem to have any problems with it, so it looks like it works. The real question is how well will it work. My thought would be the change the freehub bodies on all my wheels to 11 speed and then use the spacer kit to convert some back to 10 speed for the other bikes. That way any wheelset works with any of your bikes."
Since the above post, there were some posts speculating that it might not be so simple, that redishing might be required. Not sure why this would be the case if it really is possible to simply replace the 7900/10spd. freehub body with a 9000/11spd. body. Maybe a new end nut and/or spoke clearance issues make it so? Also, if Wayne hasn't had any problems running a 10spd. wheel (7900 hub and cassette?) on an otherwise 9000 system by simply adjusting limit screws to lock out the 11th gear, seems that's the easiest solution when you want to run your "old" 7900 wheels.
I've got 4 sets of 7900 Shimano wheels (2 clinchers, 2 tubulars) that I love, including a brand new set of C35's, so my interest in confirming I can still use these wheels with 9000 is keen.
Anything new on this, Madcow? Does Wayne says the 9000 with 7900 rear hub/cassette works well or very well or perfectly?
I know it's only been a month, just thought I'd ask :) Thanks for your great reviews and info., we've all come to rely on you for good info.!
MarvinK
by MarvinK
I'm building a new bike and trying to decide between 9000 & 9070 di2. It seems like a pretty hefty price and some bulky-looking (albiet less than that 1st generation di2) for automatic trim and most likely less maintenance. Any thoughts? Any others going through the same struggle?
BdaGhisallo
by BdaGhisallo
DI2 is pretty special. I have been on it for three years and, rain or shine, it shifts fantastically every time. Sure it's possible to execute a quicker shift with mechanical shifters, and some maintain they can do it every time, but you can't beat DI2 for dependable shifts. You come to take it for granted, shifting without even thinking about the effot, and it never lets you down.
CrazyErrol
by CrazyErrol
I spoke to Madison this week and asked them about 9000 compatibility with 10 speed wheelsets.
I was told 9070 di2 can be configured to run as 10 speed.
I hope this is reliable info!
Mike V
by Mike V
Saw this on VN today is gives numbers and what Wayne Stetina is running.
http://velonews.competitor.com/2012/07/bikes-and-tech/technical-faq/technical-faq-how-does-di2-know_228686
ave
by ave
What is this?
It's different to the 9070, so maybe an early prototype, or what?
This is official 9070
BdaGhisallo
by BdaGhisallo
Those look like some early prototype pics of the 7970 levers that circulated before the initial DI2 levers were finalized.
euan
by euan
SvenNijs
by SvenNijs
Testing an Ultegra Di2 11spd rear mech or maybe it's 105..... ?
Jan
by Jan
http://www.bikeradar.com/road/news/arti ... 000-34009/
An extra sprocket out back means a new chain. It's the same width as Shimano's 10-speed chains but has a slightly shorter pitch (the distance between the chain rivets).
Can this be correct? Shorter pitch?
micky
by micky
Bit strange indeed. :|
maquisard
by maquisard
Reading that article I think the person writing it got confused as to what pitch is and actually means the width of the river ( and chain ) not the pitch. There is no way on earth Shimano would change the pitch, there is no benefit in doing so and it would cause compatibility nightmares with basically everything. :shock:
durkonion
by durkonion
Shimano has changed the pitch before. They used a 10mm pitch for a while. With that being said, I think they learned their lesson and are sticking with 1/2 inch pitch.
