An explanation on Ciamillo Brakes performance disparity.
Powerful Pete
Location: Lima, Peru and occasionally in the Washington DC area.
by Powerful Pete
Same here. Great brakes. They work. Are good lookin'. And stop me just fine.
ZeroG
by ZeroG
thisisatest wrote:-do the double sided spherical washers come stock with your brakes?
-why are the brake calipers not designed for the widest option, then have different thickness (or stackable) spherical washers to accommodate narrower rims?
-why, on the zeroG and negG, do the brake arms run directly on the center bolt, without any bushing material? i know you guys offer a tune-up program. are the arms replaced, or is the slop taken up by other means?
-why does the top of the cam drag directly on the brake arm?
-why Campy pad holders? are you doing anything different now that Campy is using a different retension system?
thanks in advance.
The double sided sphericals come with the Zero G model because with the new cam it is the only model that requires them on 19mm rims. That's actually a good idea on the stackable washers.. we started with standard padholders before the rims got so wide and we started selling the low-profile and super-lows to existing customers who were getting these rims.. we are actually recommending the low-profile on the Neg G and super-low on the Gravitas and sending them with a bag of the double-sided sphericals lately. Also, the extra wide cams are now included with the Gravitas (the calipers are fitted with the standard cam and the extra-wide cam comes in a small bag with extra eclips).
The arms run directly on the centerbolt because they are anodized which is basically a case hardening. The PV value (Pressure-Velocity value) is extremely low in a caliper application so additional bearing surfaces are not required. Radial wear in the hole has been negligible even on sets over seven years and 50,000 miles. We see a slight swaging of the faces due to the pressure over time and this is what accounts for play developing. When we do a tune-up we sometimes replace the arms but we always replace the springnut and stainless shims.
The lobe of the cam is made of Torlon... a bearing grade plastic. This material is amazing.. excellent wear resistance yet not hard enough to gall aluminum or wear the resin of the Gravitas arms. In the aluminum brake application, we have never seen the lobe wear out nor have we seen damage to the aluminum finger that it rides against. There is minimal wear of the lobe in the carbon-fiber application so the lobe should last a very long time here as well.
No particular reason we aligned ourselves with the Campy pad style.
thisisatest
by thisisatest
thanks for the concise answers.
with the torlon cam lobe, my issue is over time, it seems to account for the kinda-crappy brake lever feel i occasionally come across. this is after cleaning and lubing the pivots, and using a fresh cable and housing.
kinda-crappy may be harsh, it's just not as smooth feeling as other brakes.
i do appreciate the ongoing updates, even if i'm not a huge fan of the brakes...
sugarkane
by sugarkane
So Ted can you do rebuild kits? I'd love to get one
StuTheWeak
by StuTheWeak
Rim width doesn't explain my brakes being sticky...I cleaned and lubed them too...cables too. Not trying to beat a dead horse.
Only tried them on my 19mm rims. I do wish I had tried them on my wider rims...just so I'd know if it would have made any difference.
Specialized Allez 06' "Rain Bike" 21.50lbs
Neuvation F100 11' "Road Bike" 16.80lbs
Specialized Tarmac Pro 11' "WW Bike" 14.25lbs
sugarkane
by sugarkane
StuTheWeak wrote:Rim width doesn't explain my brakes being sticky...I cleaned and lubed them too...cables too. Not trying to beat a dead horse.
After seeing the way you put your last bike together your issues are very likely user error.. :roll:
Mine have a very light lever action but return smarty and positively
The rear is the one people have trouble getting to spring back nicely and it's usually cause the Cable drags on a poorly cut housing. As you normally have two sections of housing there is more points for cable rub and the last section needs to have a nice curve in it that often isn't right due to the able been too short.
Other brakes can over come any drag in the cable run cause the springs are much stronger..
I think they are fabulous brakes but they are very sensitive to cable run
pholcus
by pholcus
Hi all, I mounted a set o ZeroG Ti on my Supersix. I had not much trouble setting up properly, I use alligator i-link, so I could finetune the housing lenght. Only problem I had to use the stock Dura Ace front backnut, since nthe one provided is too short.
Shame the original is 10,5 g, the Ciamillo's 1,6 g.
Maybe Ciamillo should provide two different backnuts in the package.
Anyway, on a set of AC 350 sprint, they brake very very well, plenty of power, I don't miss the DA 7900 i previously had.
williamsf1
by williamsf1
Untitled by aussie_pilot, on Flickr
see washer
mounted up without washer and on lower pads
original pads but supposedly super low pad holders....
anyone able to help me?
in the first pic you can see the little black spacer washer, does this need to be used?
I am trying to run these on 26mm wide ENVE smart 6.7 rims
trying to come up with a fix!
anyone with 3 pics of the types of pad holders
gumgardner
by gumgardner
I sent mine back to ZG to get reworked. They are so backed up with repairs (almost 2 months), it makes me believe that these are crap brakes. I told them to just send them back.
roca rule
by roca rule
i nearly pissed myself after those 5 pages :lol: .
williamsf1
by williamsf1
Any actual hep from users?????
sugarkane
by sugarkane
^^ are you reading the posts people have been making?
williamsf1
by williamsf1
Sugar....
yep! read everything previously, but I was asking about the use of the black washers... nothing to do with the performance or setup etc etc etc etc...
the question still stands, Im told these are the super low profile pad holders but cant get an answer out of ZG re: the pads setup
thats why I put the photos up....
so simply, do I need the black spacers or can I run them without them? (more width)
thanks
sugarkane
by sugarkane
williamsf1 wrote:Sugar....
thanks
Ahhhh well.. It all depends on the rims you have.. Under 21mm wide the std holders work fine... Over 21mm you'll need the Lo pro holders, I have this set up with my enve 45 rims.. Again no spacers. If you have enve smart rims or fire crests you'll need the lo pro holders and the new 'wide' cam.
From what I can tell you now get the lo profile holders, wide cam and the washers as std.
So if you have a set of 19mm alloy clinchers and the new set up the washers are going to be needed to space the pad holders in enough to work ok.
The won't change the performance of the brakes only make them work with narrow rims.
And running the cam open cause you have the old std holders does not work too well..
You end up missing the sweat spot that occurs at the beginning of the lever pull given you max performance with the least amount of pull
I'm only using this picture to illustrate the way power is delivered..
The bit where the curve ramps up hard is the sweet spot. Squeezing harder will deliver more stopping power but for every increase in power from now in requires lots more pressure..
Wide rim setup=good, spacers=narrow rims on wide rim step 8)
