Lightning crank reliability?
eric
by eric
The BB on my old FSA Carbon Pro ISIS cranks died again, and its time for something more modern. The Lightning crank looks good and isn't too terribly expensive.
Is it reliable?
gumgardner
by gumgardner
Did u read madcow's crank shootout? It talks about this crank. Not sure about about the long term reliability though.
eric
by eric
gumgardner wrote:Did u read madcow's crank shootout? It talks about this crank.
Yes, I did read it, and the one potential negative was short time in the market and thus lack of user feedback. But I know (from searching) that a number of people here have them. The one set I have seen in real life had some issues according to the owner. So I am looking for more user feedback. I'd like some reliable cranks.
a.davis12
by a.davis12
if you want reliable, buy shimano or campag.
prendrefeu
by prendrefeu
Eric, have you tried searching on this forum?
There have been at least 2-3 threads asking for Lightning crankset long-term reviews, reliability, etc:. You will find your answers there.
Frankie - B
by Frankie - B
Eric, Prendrefeu is right. Please use the search function and you will find the answers you are looking for. I read somebody said that if you want reliable, you need to buy Shimano or Campag. well. yes you can. but it is not lighter.
If you want to see 'meh' content of me and my bike you can follow my life in pictures here!
strobbekoen
by strobbekoen
Seems all replies so far are about looking elsewhere for answers.
I have the Lightning cranks, and yea, I searched high and wide for real world experiences on these before getting them.
There's not a lot of it around.
Anyway,
They are good cranks, easy to install, and of course light.
I've been riding them with Look Keo pedals, which installed fine. However, the pedal thread is recessed into the crank arm so I had to adjust my cleats a bit to avoid rubbing the crank arm. I think they should address this.
Other (small) negative is the quality of the finish. It's not bad, but also not on par with campagnolo or other top brands. Scratches rather easily. Not a biggie for me though this one. Can be rubbed out rather easily.
The adjustable bearings are a nice touch. Easy to set up. You can do it by hand, although it is a lot easier with a 36mm spanner. Expect to check this a couple times before it settles in. A couple test rides around the block are a good idea.
Overall I think they are reliable and well-designed cranks.
anderz
by anderz
I have to agree with strobbekoen on what he says. I have put Lightning cranks on my Speedvagen and must say I can not feel any difference in stiffness compared to my Cannondale System6 with Hollowgrams. I'm using the compact version with Stronglight CR2 rings and Super Record and the shifting is flawless and as well if not better than the Chorus 11 cranks I had on before.
As for the pedals, you can get a spacer to increase the Q-factor if you cannot reposition your cleats enough to clear the crankarms. Or do as I did and get Ward Industries to make a slightly longer pedal spindle in Titanium.
eric
by eric
prendrefeu wrote:Eric, have you tried searching on this forum?
Yes, I tried searching, as I mentioned above.
I found a number of posts from people saying they'd bought them, but none reporting any issues.
Which could mean that there aren't any, or that there are and no one is saying anything.
I know someone who is a bit unhappy with his.
Hence my query.
ras11
by ras11
Had my set now for almost ~2 years.. with the Quarq. Road across the country (2900+miles) with them. You have to be confident in your gear if you're riding across the US.
The cranks now come with pedal spacers, so any pedal issues should be resolved... or, if you're tricky, you can decrease you q-factor by leaving the spacers out.
Setup is easy, but as mentioned you need to keep tabs on them until the they settle. Just bring your wrench with you the first month.
I did break the adjustable lock ring. Not sure how I did that... must of got excited with the clinch bolt. Easily replaced with a phone call to Lightning and FexEx next day.
I did have some concerns about the BB bearings, but they have survived surprisingly well. Keep in mind they only have a single seal, and not well protected aginst high pressure hoses.
One of the best features of these cranks is their flexibility. You can run them BB30, or not. You can have a Quarq... or not. You can run them 110bcd, or 130bcd... easy peasy. Hard to ask that of most high end cranks.
The only beef I have is the non-tool loosening of the BB cups. Man they can get stuck on there. I keep a set of channel lock pliers around, and the supplied rubber sheet. I couldn't find a small enough strap wrench to fit the cups.
The support is fantasitc!
:-) Toys-R-Us
BobLogIII
by BobLogIII
I saw a guy break his non-drive side arm right after clipping in at the start of a race back in April. He got off easy as it was literally just as he clipped in, so he was barely moving forward & was able to stop cleanly. Never did hear the story as to what happened, but it didn't look good. Essentially a stub of a spindle sticking out & the arm completely separated. Likely would have looked much worse had it happened coming out of the final corner & heading for the finish line.
djconnel
by djconnel
Only down side I've had is they tend to creak. If I remove the bearings, grease the threads, and reinstall it solves the problem. But the whole operation is incredibly fast. So I like them.
The recessed pedals wouldn't be compatible with Metrigear Vector without a spacer, since the battery/transmitted packs screw between the pedal and the crank. So if that's on your long-term radar, keep that in mind.
It's the only down-side I see to the cranks, at least for me. I bought them in part for the promise of Quarq compatibility, which has now been realized. But a further advantage is their modular nature and flexibility. For example, it would be easy to convert them to different BB types, given the range of bearings that Tim has available. That's not to say I'm not at least a little tempted by the AX-Lightness Morpheus. But I'll probably stick with my Lightnings.
lanierb
by lanierb
I've had a Lightning crank since November of last year, with a Quarq power meter. It has about 1900 miles on it as of now. I was basically happy with it up until this week, when somehow the right pedal started wiggling around. The nut that holds the pedal in the carbon seems to be failing somehow, so I've just sent it back. Hopefully I will get it back soon because that means my main bike is temporarily out of order.
I've also had the creaking issue djconnel posted about, but only twice in 1900 miles. I removed the bearings and greased them and replaced and it went away both times. It's fast and easy to remove so no big deal.
As for riding, I've found it to be stiff and I don't notice the difference from the Dura-Ace crank on my other bike, so I'm happy with it. And obviously, it's really light.
CLB
tochnics
by tochnics
amazing thread and cranks
i was holding out lighter cranks because of a possible frame upgrade
running sr11 now with a standard bracket but these could be it
sure i can fit adapters on the records but still not as light as the boutiqe cranks
keep em coming
Join the light side
a light bike does make you go faster unless you are slow
Ritterview
by Ritterview
I have two Lightnings on my tandem (Lightning now makes a tandem crankset, which has been great because these are 1.15 lbs lighter than the FSA tandem crank heretofore the only outboard bearing crankset available). It has the same aluminum spindle as the single crank, and so is a test of robustness, as the stoker's crank must transmit the power and torque of two riders.
I am very pleased with my Lightnings. I had creaking at one point, that was solved by repacking. My shoe rubs on the crank arm, which rubs off the Lightning logo sticker, which is perhaps for the better. I could use the spacer I guess. On tandems too the modularity is useful, first as a triple is available, and both captain and stoker can individualize the crank length (175 captain, 170 stoker for all on the FSA).
