SRAM Red Rear Derailleur Tuning
The general all-things Road forum!
prendrefeu
by prendrefeu
What does a normal pair weigh for comparison?
TARE
by TARE
The pair i had on scale 34.4g
prendrefeu
by prendrefeu
WOW! That's great work! Did you make your own mould?
(I'm guessing you work with Jure, no?)
4ibanez
by 4ibanez
:beerchug: some proper WW going on in this thread once again
Berk
Carbon Composites
by Berk
prendrefeu wrote:
Thu Jan 25, 2018 9:17 pm
Yes, TARE is our guy :thumbup:
We made a composite mould from the original part and used M40J fibers to produce a stiff part, and it turned out really nice. It is for the <4kg bike project from TARE
godzuki26
by godzuki26
Here is a link to my step by step process on tuning a RED 22 Derailleur:
:arrow: 2016 SRAM RED 22 rear derailleur tuning
:arrow: BH Ultralight
:arrow: Litespeed Ghisallo
ImageCannondale Evo HiMod
ImageFelt AR FRD
trainingpartner
by trainingpartner
Early doors Sram red 22 with integrated hanger.
The project is further along than these photos suggest and will update shortly. Currently working on the nylon bushings and carbon pivot pins+Circlips
The idea is to use the stock inner parallelogram arm (will be tuned) on the spring carrier cage/elbow(custom springs) and build everything else out from that.
Threaded insert for cable clamp bolt (L168 threaded M4) (7075 bolt max torque 3nm.)
this photo shows the punch marks that secure the pivot bolts in the bushings in the OG Red mech.
Weight will be half of anything on this thread.
"Work inspired by Ales arnez"
trainingpartner
by trainingpartner
The final Skeleton shot before things went RED
OtterSpace
by OtterSpace
glad to see people engage with this again. Not something I'd do but this is truely some next level stuff. Looking forward to more details and long term feedback as I know you will beat the heck out of it and are fine pushing things to the limit in race conditions.
:beerchug:
trainingpartner
by trainingpartner
Barrel adjuster and insert
Trying to figure out how to attach the mech to the bike
Ended up deciding to machine some alloy inserts which will be bonded into the mech and the big flanges will provide some QR clamping surface
trainingpartner
by trainingpartner
97g without pinch bolt and arm.
Stock jockey wheel and cage untuned. Steel bolts
