Has anyone broken Fibrelyte full carbon chainrings???
- Mattias Hellöre
- in the industry
- Contact:
They should last good enough like Fibre-Lyte said but be careful when you shift so the teeths remain unsplintered.
Others than that - no problem.
Experimental Prototype
Someone commented about the look of FiberLyte rings on Claviculas, well here's an example:
PS I also realize the DA7900 chain is on backwards in this photo--it's been reinstalled correctly.
dr Phil Gandini
Link to my 11.5lb Neo Ultimate
Just picked up a set (50/36) for my compact AX Morpheus bb30, which has been set back to December 2010. Oh well. The rings are nice to look at
- HammerTime2
- Location: Wherever there's a mountain beckoning to be climbed
Weather in PA should be getting nice when you get your Morpehus cranks ... in May*.
* O.k., I'm an optimist, so sue me.
I don't know. Nils told me December for the bb30 compact. We'll see. Fingers crossed.
Unfortunately there is damage on my 50T chainring
Noticed that the shifting wasn't as good so removed the cranks for a good clean and overhall.
Found that a shifting pin had torn out
Bike:
9.2Kgs ---------------------------I- 5.8Kgs
Me:
90Kgs -----------------------I------ 84Kgs
Me:
Best choice is Carbon-Ti chainring ! Carbon-Alu or full titane
Very good shifting, light and durable...
On 3 bikes since 5 years with no problems. See on my website...
www.baron-noir.com
Specialized Aethos SUB5
Specialized Tarmac SL8 - 5.35 kgs
Specialized Tarmac SL6 - 5.16 kgs
Scott SPARK RC 900 SL SUB 8
Specialized Epic HT - 6.18 kgs
Ok, I'm definitely gonna superglue round the edge of my lift pins!
They've been reported to have some issues...
https://weightweenies.starbike.com/foru ... p?t=147767
(For the record, I still have them on two bikes. They are light...)
- in the industry
- Contact:
Shock horror that a full carbon chainring sometimes fails. I had them. After 4000km I destroyed several teeth. When I shifted I made sure it was smoothness I don't think the rings tollerances abuse.
The models in full titanium are very good...
http://www.carbon-ti.com/products/chain ... chainrings
www.baron-noir.com
Absolutely. I don't shift under load regardless of the rings I'm using.
Fibre Lytes are a special product that needs to be used considerately. I chose a 51t big dog even though I like a 52t. This is to minimise the need for front shifting and it keeps me down the middle and smaller end of the cassette most of the time (less often in a gear with a bad chainline). I probably could've gone 1x with my terrain, but nice to have the small ring option.
After a year of use, I have about 5 tooth that are chipped or split down its side into half, with another 2-3 that are split open but with both sides still on. Always treated them carefully. Sometimes they shift smoothly but sometimes it'll be resting on top of the teeth first before settling down.
Bought extralite chainrings to swap it out if it ever starts to skip. Will gain 10g and peace of mind.
