Stem for 1 1/4 "
As Mackers has said 31.8 is 1 1/4", the bar stem combo is supposed to comes with a shim to fit 1 1/8" a bit like the Syntace F119 stem,
Another stem option that i currently use is the 2016 onwards Syncros RR1.0 aerostem, as used on the Scott Foil, pretty light and stiff.
motorapido wrote:Another stem option that i currently use is the 2016 onwards Syncros RR1.0 aerostem, as used on the Scott Foil, pretty light and stiff.
Is it currently installed on your bike? could you post a picture of it?
Zipp SL-OS on my Ultimate:
Well the bars turned up today and were well wrapped in foam although just being in plastic postal bag was a bit worrying, but they appear to be spot on.
they come with 2 x 5mm and 1 x 10 mm spacers, step down shims to 1 1/8" steerer and a moulded top cap. nice clean text and logos on them with a Canyon logo, they say H11 on the side of them. Not sure what the difference between H36 and H11 is, any one know ?
Will post up some pics and weight tomorrow.
I believe H11 is the Aeroad fit and H36 is the CF SLX fit.
Photos and info posted here to save double posting all the info
viewtopic.php?f=3&t=144200&p=1301577#p1301577
Anyone of you know an online source (in Europe) for a 130mm 1 1/4 -10° pro stem? The older ones are all sold out, and the newer ones are (not yet?) available.
Current bikes:
Scott Addict Premium Disc 2018
Scott Addict Orica Greenedge 2015
Retired:
Canyon Endurace CF SLX 2016
Canyon Ultimate CF SLX 2013
Retired:
Giant offer a 130mm 8degree one, you should be able to get one for about £140/€160.
https://www.giant-bicycles.com/gb/giant ... -1-8-fork-
I still really like how this thing looks.
weight:
100mm-146g
110mm-154g
120mm-156g
130mm-158g
will probably pick one up next year. or maybe the Vision version.
weight:
100mm-146g
110mm-154g
120mm-156g
130mm-158g
i've been shopping for a steam quite a bit for my Giant TCR.
Here are some lightweight options that work with a 1.25in steerer tube.
- Zipp Service Course Sl-OS
- ITM X-One
- Ritchey
- Giant SLR Contact
- Ritchey Superlogic C260
- Ritchey WCS 4-AXIS
- Shimano PRO Vibe
- ITM X-One
- Ritchey
- Giant SLR Contact
- Shimano PRO Vibe
Here is a full list of 1 1/4" (or 1.25") stems available as of now (*Prices may vary depending on shops)
Almost all of them come with a shim for 1 1/8"
Giant Contact €25*
Canyon V13 €50*
Syncros Aero RR1.5 Foil €60*
Ritchey WCS 4-Axis 44 €65-74*
Ritchey WCS C220 84D €80*
FSA SL-K 6°/17° €80*
PRO Vibe 1 1/4" Di2 €88*
ZIPP Service Course SL-OS €98*
Ritchey Superlogic C260 Carbon €180*
FSA K-Force Light Carbon €190*
Giant Contact SLR Flux €225*
Vision Metron 6° Carbon €260*
Some that are hard to find/might have been discontinued:
Integrated systems
Giant Contact SLR Aero Integrated Road Handlebar and Stem €400*
Canyon H11 / H36 Aerocockpit €400
Canyon H31 Ergocockpit €400
Syncros RR1.0 Aero Bar/Stem €486
If you know any other 1 1/4" stems that I missed, go ahead and post it here
Giant Contact €25*
- AL6061
- Flip-Flop +/- 8 degrees
- Weight: ca.172g (100mm)
- AL7075
- Titanium hardware
- Color option: black, white
- Weight: ca.156g (100mm)
Canyon V13 €50*
- AL7050
- Flip-Flop +/- 6 degrees
- Weight: ca.153g (100mm)
- AL7075 + UD Carbon
- -6 degrees angle
- Weight: ca.160g (100mm)
- AL2014
- 84/6 degrees
- Weight: ca.124g (100mm)
- AL2014
- carbon encased body
- CrMo bolts
- 84/6 degrees
- Weight: ca.121g (100mm)
- AL2014
- UD carbon faceplate & top cap
- CrMo bolts
- adapter for 1 1/8
- 6 or 17 degrees versions available
- Weight: ca.141g (100mm)
- AL7075
- Titanium bolts
- internal Di2 cable routing
- -10 or -17 degrees angle
- Weight: ca.125g (100mm)
- AL7075
- Titanium hardware
- Weight: ca.140g (100mm)
- UD Carbon + AL2014 faceplate
- 84/6 degrees
- UD Carbon + alloy faceplate
- Titanium hardware
- Weight: ca.150g (100mm)
- Titanium hardware
- Weight: ca.146g (100mm)
- Titanium hardware
- Giant Contact SLR OD2 carbon +/- 8 degrees
- ITM X-One carbon -10 degrees angle
- Syntace F119 +/- 6 degrees
Integrated systems
- UD Carbon
- 3° backsweep
- -6 degrees angle
- (H11 and H36 have different drop and reach)
- Full Carbon
- Full cable and wire integration
- Mounting kit required sold separately (€30)
- Full Carbon
- 6° backsweep
- Full Carbon
- Ergonomic Compact Bend, 80/130 Reach/Drop
I think the Specialized Comp Multi Stem is designed to fit a 1-1/4" steerer if you mount it without the shims used to set different angles (when mounted to a 1-1/8" steerer).
Giant TCR Adv Pro Disc '17 · BH Lynx Race Evo '19 · Seraph GR029 '21 · Canyon Inflite AL '14
