http://sheldonbrown.com/power_wheel.html
Racing Aardvark wrote:All I'll say is, what kind of education do you think most people working (or riding) for cycling teams have? Heck only a SMALL percentage of American pros have any college education. In Europe it's even worse(there are a few exceptions!
Now, remember that MOST people working for pro teams either were pros or have always been involved in cycling. How many business people or people with careers give it up to work for a team? Very damn few. So, given the limited pool of candidates, what do you think the average IQ is?
(I do know a few, for instance a mechanic with a Masters in Sports Psychology, and a team director with a degree in Physiology, and there's actually quite a few MTBers with college degrees in advanced fields, but they are the EXCEPTION).
If you ride uphill on a bike with standard wheels and then freewheel, then do the same test with light wheels and an appropriate amount of ballast (so you still have the same mass) I suspect that you will stop sooner on the energy storing heavy wheels.divve wrote: A heavier wheel will take more energy to accelerate, but it'll also store more energy, and susequently decellerate at a slower rate. The only time you actually loose that energy is when you brake. This doesn't happen much going uphill.
ultimobici wrote:If you ride uphill on a bike with standard wheels and then freewheel, then do the same test with light wheels and an appropriate amount of ballast (so you still have the same mass) I suspect that you will stop sooner on the energy storing heavy wheels.
It won't be much of a difference but it will be there.
mises wrote:"micro accelerations"
asphaltdude wrote:mises wrote:"micro accelerations"
With micro accelerations we only mean the minor changes in speed that occur with every pedal stroke.
mises wrote:asphaltdude wrote:mises wrote:"micro accelerations"
That's what I am talking about also - just pointing out they aren't necessarily micro regardless of how smooth you may feel pedaling. The fluctuations happen so rapidly it's easy to feel like you are maintaining a fairly constant speed when you aren't even close.
divve wrote:Micro accelerations? Must be some sort of BS you heard from Dr. Ferrari. A heavier wheel will take more energy to accelerate, but it'll also store more energy, and susequently decellerate at a slower rate. The only time you actually loose that energy is when you brake. This doesn't happen much going uphill.
The reason for light wheels feeling so much "lighter" is a combination of several factors.
Less mass at the outer perimeter allows for easier directional changes.
Acceleration feels quicker, for most this more apparent than the energy you get back from heavier wheels when slowing down.
High-end carbon competition wheels are very stiff and often use a heavy gauge, relative short spokes, or composite such as Lightweight. This gives you the feeling of much more snap compared to a lightweight CX-Ray box rim type of wheel build.
Finally, what pros choose, Riis and CSC, or Cees Beers think, is hardly an argument supporting laws of physics. If you want to back up your statements bring in the math. Be prepared to disprove Newton's laws when you do so.
Knock yourself out. There's a Nobel prize waiting for you on this for sure.
http://csep10.phys.utk.edu/astr161/lect ... 3laws.html
http://www.analyticcycling.com/
allezkmiec wrote:mises wrote:asphaltdude wrote:mises wrote:"micro accelerations"
One need only look at the water in a half-full water bottle to prove how un-minor these accelerations really are. Even on a gradual, more constant climb, the water sloshes forward and back quite a bit, demonstration very clearly the acceleration/deceleration pattern.
fdegrove wrote:Hi,The only time you actually loose that energy is when you brake. This doesn't happen much going uphill.
Somehow I think gravity combined with the combined weight of the rider and his bike make for a nice set of brakes. Ones that are constantly on for as long as the climb goes no less......
For going uphill, there's no doubt in my mind that the reduction of the weight at the rim and tyres are a major advantage as a continous series of impulses from the drivetrain are not only needed to keep going forward, they're needed to prevent the rider from coming to a grinding halt.
That's why you'd want to go uphill using a big cog so you can speed up the sequence of pulses and keep the energy flow as constant as possible.
To make it even easier you definetely don't want to drag unnecessary weight against the forces of gravity....
Hold on....
Gravity? Wasn't that the same good ole Isaac Newton again? Ah...Plus ca change.....
