athletic91 wrote:Mine came in at 1050g
Pic with my pedalforce RS2
I have those same skewers and I do not like them, they are not nearly as nice as even some of the cheaper Chinese skewers and definitely not nearly as good as KCNC's.
aidanr wrote:Out of interest, what's the difference between the Soul Prodigy V3 and V3.1 hubs, other than $30?
WheresWaldo wrote:aidanr wrote:Out of interest, what's the difference between the Soul Prodigy V3 and V3.1 hubs, other than $30?
From my recollection of an email exchange with Sean, the rear hub is a bit lighter and now has 6 pawls.
athletic91 wrote:xnavalav8r
Have u gave it a second chance to see if the spoke came loose again
delsol wrote:Any of you guys riding with the 20mm clinchers?
athletic91 wrote:delsol wrote:Any of you guys riding with the 20mm clinchers?
Ive seen one in my local community. came up to 1280g even with light 280g hubs/Aerolite spokes 20/24
In my opinion its better to get the soul 2 clincher at 1308g with added durability and at a lower pricepoint
The whole purpose of a 20mm wheelset is a target of 1000g wheelset.
(against the sprit of WW, i stupidly glued on some conti sprinters)
WheresWaldo wrote:pino76 wrote:WheresWaldo wrote:chrisw28 wrote:Just got my wheels built up...gonna glue on some tyres tonight. Archtek 20mm rims, cx-rays, 1037grams
Just built up the same wheels, wound up at 1036g. Acrhtek 20mm, Soul Prodigy v3.1 hubs (Black with blue endcaps), Sapim CX-Rays, DT Alloy nipples (Blue).
What lenght of spoke did you use, and how did you figure out the lenght. did you use a spokecalculator?
Both spokecalc and DT come out with the same measurements. Problem is Sean has not update his site in a while other than the new pricing for v3.1 and not all the measurements are accurate. Here is what you need to use:
BikeSoul v3.1 Front:
Spoke hole: 2.4
Diameter, LF: 31.0
Width from center, LF: 39.3
Diameter, RF: 31.0
Width from center, RF: 39.3
BikeSoul v3.1 Rear:
Spoke hole: 2.4
Diameter, LF: 35.5
Width from center, LF: 48.0
Diameter, RF: 59.0
Width from center, RF: 17.5
These measurements were verified using digital calipers.
