New powermeter rumours
AZR3
by AZR3
I'm going to run the following setup on my Evo Hi MOD
SRAM Red BB30-total weight, with chainring bolts, 363.9g
Extralite 50/34-95g
Assioma Duo-300g
Total weight-758.9g
For comparison, my SiSL2 P2M Extralite setup with Xpedo Thrust Ti pedals weighs 761g, so basically identical but now I can sell my other power meters and just swap pedals
nemeseri
by nemeseri
AndreLM wrote:
mag wrote:By the way what would be the most WW PM solution giving total power data (not just doubled single-leg data)? My guess is THM Clavicula SE with Favero Assioma pedals...
And what would be a decent alternative for crank based PM (excluding the ridiculously expensive SRM+Clavicula M3 option)?
Probably (the still not available) Specialized Power Cranks (AFAIK co-developed with 4iiii)
or
Cannondale SiSL2 with spiderings and Watteam Powerbeat sensors
and your choice of WW pedals
Both would only fit BB30/PF30/OSBB/T47 frames though
Pioneer adds about 60g to the crankset, and with FC-R9100 that would be around 670g-680g for the compact. And 690-700g for the standard. Shimano's own PM will be in this range too.
mpulsiv
by mpulsiv
AZR3
by AZR3
mpulsiv wrote:Watteam is down to $259? https://shop.watteam.com/powerbeat-single
That looks like it'd be very fragile, I'd be worried I'd rip that wire out or damage the unit.
mag
by mag
That Specialized S-Works Power Crank looks interesting, but it's really a "virtual" product as of now - no mention of availability anywhere, it even disappeared from the specialized.com website (where it had its own product page previously). Seems to be similar story as with the Shimano power crank which was also announced like ages ago and yet it started to be available only a while ago and only in selected countries (mostly Japan it seems).
It's a shame that Pioneer isn't available in EU much (only limited availability of some single leg models) and they make it only for the Potenza crank in the case of Campagnolo. It would be a nice option otherwise.
By the way the P2M NGeco is available for purchase since yesterday.
moyboy
by moyboy
Yes very fragile especially for the cx crowd!
moyboy
by moyboy
Are the pioneers still only Ant+ and not Bluetooth?
or
nemeseri
by nemeseri
moyboy wrote:Are the pioneers still only Ant+ and not Bluetooth?
Yes.
mentok
by mentok
So is the watteam the cheapest way to get power onto a bike at this point? Assuming it actually ships, and aside from second hand, obviously.
topflightpro
by topflightpro
Maybe.
Of course, if it turns out to not work and you have to sell it at a loss and then buy something better it will ultimately cost a lot more.
TobinHatesYou
by TobinHatesYou
If you’re serious enough to train with power, then you should probably at least go with one of the more established left-only options. Vector 3S or Assioma Uno would be my two choices, but I’m already a KeO compatible cleat user.
mentok
by mentok
It's for my wife's bike so she can ride zwift with some semblance of accuracy. She's not particularly serious but having something realistic for her would increase her enjoyment and get her on the trainer more often.
We have a smart trainer we share which spits out garbage power numbers so when she uses it either she's a flyer or she's hardly moving. It's a toss up between upgrading the trainer or putting a cheap powermeter on her bike. I don't want to shell out 1k to upgrade smart trainers because the one we have works fine for my purposes and she doesn't use it that often right now, plus if I'm going to spend the money I'd want direct drive which means we have to get our drivetrains compatible (she's 10sp, i'm 11sp). All a big PITA, so a dirt cheap powermeter seems to make more sense.
Anyway, this isn't the "which powermeter should I buy" thread so I'll take my hat in my hand and keep thinking...
HammerTime2
by HammerTime2
Someone should make a list of all the powermeter rumours on this thread which did not pan out. I believe there are many.
I'll start off with an easy, high profile one: Brim Brothers. Zone anyone?
glepore
by glepore
The problem with watteam is the subscription. I like to own my stuff, not be on a monthly plan...
If you want a really cheap perfectly working computrainer pro and you're in the US, pm me. Its surplus here.
Cysco Ti custom Campy SR mechanical (6.9);Cannondale SS Evo Di2 7970 (5.79); Willier Cento Uno Air Di2 9070 (7.0); C40 Mk2 DA 7800 ; Anvil Custom steel Etap;1996 Colnago Technos Record
TobinHatesYou
by TobinHatesYou
glepore wrote:The problem with watteam is the subscription. I like to own my stuff, not be on a monthly plan...
Watteam is the janky looking self-install PM with the miniplug charging interface.
ZWatt is the PM with the subscription plan.
