What tools to remove Sram Red crankset?
Wow. A lot of people don't know what's going on.
You need a 8mm hex wrench and an external BB tool.
Unscrew the 8mm hex bolt with the 5/8 in large bolt still in there. The 5/8 is the "Self extractor" and allows you to remove the crank without using a crank puller. Rightey Tightey Lefty Loosey.
Use the external BB tool to remove the external BB. Turn in the direction of the pedaling motion to remove the BB from each side.
I can't get it to work. I unscrew the small bolt about a quarter turn and then it stops. Even with what is probably too much force, the thing will not budge. Color me idiot, but I can't get the small bolt to come out without taking out the larger nut.
Try putting grease between the small bolt and the larger self extractor. The self extractor shouldn't be spinning with the smaller bolt. It should get harder once the smaller bolt hits the self extractor.
Edit: How big is your 8mm hex wrench? I hope you're not using a multi-tool or something similar.
durkonion wrote:Try putting grease between the small bolt and the larger self extractor. The self extractor shouldn't be spinning with the smaller bolt. It should get harder once the smaller bolt hits the self extractor.
I swear I've done this but I'll try it again. I am a bit "mechanically challenged", so it'll probably work this time.
I'm using a regular L-shaped hex wrench. It should be fine.
I'll check back after lunch...
Thanks for the help you guys!
- WannaBeSTi
I agree with everyone who has said to only use an 8mm wrench and to leave to other alone.
It has been in my experience that the Red cranks can be a bear to get off, but I just keep applying force. In the past when I've removed one it has made a loud pop when it finally breaks loose.
Try this:
Insert your 8mm wrench 180 off from the non drive crank arm
Stand on the drive side of the bike and reach you right arm through the frame or over the tope tube
Put your left hand on the drive side crank arm
Then apply a hell raising amount of force to both the wrench and the crank arm (the force you apply to the crank arm will be counter to the wrench)
Stop only if you have broken the bolt loose or you black out
If that doesn't work, take it to your LBS. Let someone else bloody themselves.
Try this:
You can't have manslaughter without laughter.
This board would be a nicer place if everyone would take themselves a little less seriously.
