Tillquist's kitchen!
Butcher wrote:I got an email that mine's being shipped. Since it's not in English, I'm just assuming that.
same here, but also guessing. can somebody transalte?
Hej. Din ordre hos Edge Mount Shop er nu ekspederet. Du kan se ordredetaljerne nedenfor.
Ordre nr. 25
Produkt Antal Pris
Mount 28
3T ARX
Restordrebestilling: 1 1 € 40.50
Subtotal: € 40.50
Fragt: € 4.36 via Weight Based Shipping
Betalingsmetode: PayPal
Total: € 44.86
thanks!
Hello. Your order from Edgemount Shop is now executed. You can see the order details below
Sent from my GT-I9505 using Tapatalk
looks nice. that's how i have my junction box mounted with zip ties. haha. it would be nice to have some type of mounting system from Tiliquist regarding Di2 mount. although i can't see my zip ties with the Garmin on top like yours...it still seems so jury rigged.
- Factor Ostro VAM Disc
- Factor LS Disc
- Specialized Aethos Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
- Factor LS Disc
kode54 wrote:looks nice. that's how i have my junction box mounted with zip ties. haha. it would be nice to have some type of mounting system from Tiliquist regarding Di2 mount. although i can't see my zip ties with the Garmin on top like yours...it still seems so jury rigged.
On Tillquist's last go around I had him make a mount where the center section was not quite milled all the way through. Then I took the junction box using one of these https://www.shapeways.com/product/FS2DM ... pe-on-clip , and used double sided tape to secure it to the Tillquist mount. Looked very nice. Sorry no photos. During the time of Tillquists dormant activity I moved on to Fetha mounts. Fetha posted one on IG which was light, and uses a plastic insert for the Garmin. They made it to my dimensions in a few weeks. 14grams https://www.instagram.com/p/_a98ZHikK5/ ... ents&hl=en Highly recommend as an alternative if so desired
the Fetha mounts all look chunky and overly done. i do like their titanium 3D printed one...and asked about making a mount underneath and a spot for the Di2. they came back and told me that all those items may be too heavy for that mount.
i still haven't found anything as nice as tillquist's mounts. i am using an Enve mount on one of my bikes and find that one nice, but still not quite as versatile as it could be. i used one of the shapeways mounts that you describe and mounted that under but the automobile double sided tape eventually came loose. wasn't a secure solution. thx for your trial and tribulations.
- Factor LS Disc
- Factor LS Disc
