Short vs. long legs
Your legs are:
short
72
31%
normal
41
17%
long
122
52%
Total votes: 235
TonyOliver83
by TonyOliver83
Height 183
Inseam 91
Wingspan 190
Use 79.5 bb to saddle top
Most frames are 55-56.5 top tubes. With 120-110mm stems.
Narrow shoulders so use 40cm ctc bars.
Eg colnagos -
C59 56T with 120mm stem
V2R 54S with 110mm stem.
Run about 11cm drop.
alanyu
by alanyu
Height 170
Inseam 80
Wingspan 176, 178 if really stretched out
BB to saddle 69.5
Normal legs but long arms
usr
by usr
MikeM wrote:
Tue Jan 09, 2007 9:07 pm
Height: 185cm
Inseam: 96cm
(BB to saddle: 84.7cm)
Definitely long legged...
Oh, that's even more radical than my inseam 99 at 196 (or 197?)!
gorkypl
by gorkypl
Good thread, I kinda do statistics for living.
My data:
Height: 182
Inseam: 88
Saddle height: 79 (a tip from a local bikefitter guru, saddle height = inseam - 9cm is a very good starting point for fitting many people around this height - in my case no adjustments were needed).
Fuji Cross 1.5 - Shimano 105 5800 | Cinelli Superstar Disc - Record 12s | Custom steel Karamba - Ekar 13s
Hexsense
by Hexsense
height: 169cm
inseam: 78.5cm
So, on the long side of my height.
sychen
by sychen
height: 170cm
inseam: 77.5cm
Short legs,short arms and long torso.
Fit a Specialized Tarmac 52cm with 80mm stem or can go 49cm with longer stem.
Sent from my Pixel 4 XL using Tapatalk
octav
by octav
Height : 177
Inseam: 84.5
Saddle Height : 74cm
Colnago C60 52s si 11cm stem ; when I was racing was using a Colnago CX1 50s with 12cm stem for a more aggresive fit
Gunter73
by Gunter73
Long legs : 180cm vs 89,5cm inseam
Ypuh
by Ypuh
Long legs as well.
Height: 185
Legs: 92.5
Saddle height: 81cm
S3/R3 without spacers is a perfect fit, not too long, not too low, not too upright (Synapse/Roubaix) either. Canyon Endurace would be another good option.
Cervelo S3 - 7.3kg
Time ADHX - 8.7kg
kofsw4
by kofsw4
Height: 178
Inseam: 86.5
Saddle height: 75.5
Long arms to match the legs so riding a 54 with 110 stem and 11cm of drop
Maddie
by Maddie
Short legs
Height: 178
Inseam: 81
Saddle height: 71cm
Juanmoretime
Administrator
by Juanmoretime
Height: 183 CM
Inseam: 88.9
Saddle height 78
Long legs, short torso.
100mm stem on all bikes except the fat bike.
wooger
by wooger
How are people measuring their leg length?
Tailors inseam?
Cycling inseam (via a hardback book)?
Other?
Using cycling inseam:
Height: 195cm
Legs: 91cm
Ratio: 0.47
I'm well aware I have a long back - I sit 6 inches taller than my friend of the same height.
Juanmoretime
Administrator
by Juanmoretime
[quote=wooger post_id=1709977 time=1634594797 user_id=109195]
Tailors inseam?
Other?
Height: 195cm
Legs: 91cm
Ratio: 0.47
[/quote]
FWIW I took my inseam length from a bike fitting session.
eurperg
by eurperg
Height: 184 cm
Legs: 92 cm
Saddle height: 80,5 cm
Wingspan: 190 cm
Long legs, short torso, long arms, flexible. Usually riding 57 mm top tubes with 120mm stems, or Colnago 54s with 130mm stem.
