Short vs. long legs
Your legs are:
short
73
31%
normal
41
17%
long
122
52%
Total votes: 236
Steel[CZ]
by Steel[CZ]
I noticed that quite many people on this forum says that they have long legs (in compare to their torso). Is in WW community more long-legged people than in normal population? (Strange question, I know :))
I think 180 cm / 88 cm inseam could be consider as a average leg lenght. (0.49 ratio between legs and body). If it is wrong, correct me.
I read on some bike-fit page that american people have in average shorter legs than europeans. Is it true?
HisRoyalThighness
by HisRoyalThighness
I´m 182cm with 90cm inseam, which makes for a ratio of about 0.49. I guess that if you ask someone if they think their legs are short, average, or long most people will answer based on absolute length rather than the ratio of total body heigth/inseam.
Die Grenzen meiner Sprache sind die Grenzen meiner Welt
carbonhuhn
by carbonhuhn
Iam 188cm and my legs are 91cm long. 8)
I like long legs but its takes very long get get them thick.
:lol: (like TOM) :lol:
CARBON RULZ
The Master Cylinder
by The Master Cylinder
I found a formula for "normal" height:inseam ratio. The normal or average ratio is 2.2:1. For example if you are 176 cm tall, your inseam should be 80 cm.
I'm 185 cm tall and my inseam is 93 cm. My ratio is 1.99. So I need a longer torso to be normal.
brian
by brian
180 cm and 93 cm
Steel[CZ]
by Steel[CZ]
Oh, you are right. I meant the ratio of course. I don't know how to change the question now.
Steel[CZ]
by Steel[CZ]
The Master Cylinder wrote:I found a formula for "normal" height:inseam ratio. The normal or average ratio is 2.2:1. For example if you are 176 cm tall, your inseam should be 80 cm.
2.2 is too high IMO (0.49 is inverse 2.04). It also depends how people measure the inseam.
BmanX
by BmanX
I am 177.8 cm tall with an inseam of 81.28 so I am at .46 or 2.19 (which ever way we are reporting it)
As for thick legs, I do not have a problem with that.
Calves 46 cm
Thighs 69cm
Genetically cursed. I have never been able to touch my toes so flexibility is a problem that I work on all the time.
occor
by occor
173cm height
80.5cm inseam
ratio: 46.5
...short legs for sure
DaveS
by DaveS
I'm 168cm tall with an 83cm inseam. The ratio that I find more meaningful is height/inseam = 2.02 or the reciprocal is .494. I haven't read of many riders my size with longer legs.
A short inseam would be 5cm less, or a 2.15/.46 ratio.
yourdaguy
by yourdaguy
Short for sure, my ration is 45.7. Actually, my upper legs are normal, my lower leggs are short.
For certain parts stiffer is more important than lighter.
Ivan
by Ivan
Height: 185 cm
Inseam: 94 cm appr.
Ratio: 50.8
Long legs, no denying it.
He ride a bike instead of a car I wanna be his friend
Golden Earring - Going to the run
DB
by DB
I am 183cm tall ,86.3 inseam.
ride, eat, sleep, repeat !
etownfwd
by etownfwd
170 tall, 75 inseam. 44.1 ratio.
At least I THINK I did it right... You'd think that someone who deals with numbers for their job might be able to do simple addition and subtraction!
:oops:
Now, does that give me long legs or a long torso?
-efwd
Ramjm_2000
by Ramjm_2000
Ht: 175cm
Inseem: 81cm
Ratio 2.16
I've always considered myself to have short legs.
