SRM cranks Q factor: Pro cranks vs Dura Ace SRM
Anyone know what the Q factor is for the SRM pro cranks and how it might differ from the H-Tech Dura Ace cranks they modify with their spider?
I am thinking of getting a second powermeter and the regular pro pm is cheaper than getting a second DA pm. However, if the Q factor is that different it might throw a fly in the ointment.
Any ideas?
And, to be sure, when I say Q I am referring to the distance between the crank arm faces where the pedals thread in. The width of your feet's stance when pedalling.
Thanks.
Geoff
Any ideas?
Thanks.
Geoff
I'd love to know this too. I wrote to srm last week for anwser but no reply yet. I've searched there site and nothing either. i want to use srm pro in training but dura ace cranks on big races, but if the q factor is too different it might feel funny on race day
we just need someone too measure it themselves by putting both cranks facing foward and using some measuring calipers, digital would be best
- Resident Pro
- Contact:
The SRM DA has the same Q-factor as a normal DA crank.
The SRM PRO(non DA,FSA.....or whatever) has a Q-factor of whatever you want. You can change this by using different BB sizes. 105,107,109,111,115 etc........
zakeen wrote:The SRM PRO(non DA,FSA.....or whatever) has a Q-factor of whatever you want. You can change this by using different BB sizes. 105,107,109,111,115 etc........
But I thought that the octalink bb only came in either double or triple chainring lengths??
zakeen wrote:The SRM DA has the same Q-factor as a normal DA crank.
Agreed but this will also affect the chain line.
- Resident Pro
- Contact:
cambo wrote:But I thought that the octalink bb only came in either double or triple chainring lengths??
This Im not sure, you might be right as I was talking about the Square Taper version. I wouldnt get the Octalink as this is "tech" thats dieing!
Square taper will be around for ever. There are many options for stiffness versions and light ones. Also different sizes.
- Resident Pro
- Contact:
Taz wrote:zakeen wrote:The SRM DA has the same Q-factor as a normal DA crank.
Yes chain line will be affected when you change the BB length. However BdaGhisallo was asking about Q-factor.
I played around with Q-factor a while ago with my SRM and never had any problems setting up the gears with different Q-factors.
zakeen wrote:Taz wrote:zakeen wrote:The SRM DA has the same Q-factor as a normal DA crank.
So we both agree
Most Q's are fairly close (around 147 with average BB), but one thing you can do depending on pedal/cleat/shoe type is that there is often a small amount of adjustability in the placement of the cleat that could compensate for any differences.
For certain parts stiffer is more important than lighter.
cambo wrote: i want to use srm pro in training but dura ace cranks on big races...
Perhaps slightly off topic, but as someone who is almost ready to pull the trigger and order a D/A SRM to use on two different bikes (for training, racing and TT... all uses), I am curious why you would want to race and train on different cranks? Is there an advantage to doing so, or a disadvantage to not?
wilmar13 wrote:cambo wrote: i want to use srm pro in training but dura ace cranks on big races...
I'd train on D/A Srm but can't afford it so have to settle for the pro model. big races don't need the powermeter so will go with the lighter and stiffer dura ace cranks.
i think it is only recently that we are seeing people "racing" on powermeters. they used to be training only. but since the dura ace and fsa models became available and the 6.8kg rule came in it's easier to have light bike with powermeter.
