Jittery Joes team bike on cyclingnews.com - with ZG cranks
chisa
by chisa
VeloScaper wrote:
chisa wrote:if you are an unfit fat bastard who cannot climb.
Yea, that Ivan Basso using a 52/36 12-27 in the Giro is an unfit fat bastard who cannot climb. :roll:
that is in a very difficult stage race with climbs reaching 15%+ for over 10 miles (mortirolo, gavia), not some "all the gear no idea" struggling up a 8% on a drua ace equiped R3 at 3mph :D
shabbasuraj
by shabbasuraj
Dura Ace will be powered by cold fusion, by the time a ZG crank is released.
Mass Weenie
alienator
by alienator
richardtoddywoddy wrote:Or have a high cadence.... or rarely use your largest gear... or don't see big gears but rather speed over an entire ride as a measure of how good a rider you are...
I'm a good climber, and a spinner. Compact appeals to me because I'm not a sprinter, and it is lighter. In about 1994 shimano did it with MTBs, I'm just surprised it has taken so long.
Exactly. Compact vs. standard says almost nothing about fitness and instead says tons about riding style and preferences. The idea that you can't perform at a high level without a 52/11 or 53/11 is ridiculous.
RTW
by RTW
@ alienator, I think you are forgetting that by thinking the way you do you aren't promoting the elitist image that roadies have, where it is customary to look down on any other cyclists and view them and all new devolopments with the greatest contempt! That mountain biking thing.... just a fad too you know! :lol:
alienator
by alienator
richardtoddywoddy wrote:@ alienator, I think you are forgetting that by thinking the way you do you aren't promoting the elitist image that roadies have, where it is customary to look down on any other cyclists and view them and all new devolopments with the greatest contempt! That mountain biking thing.... just a fad too you know! :lol:
I only look down on Madcow, but that's because he's only about 4'9" tall and weighs something like 83 lbs. So I'm like 28% taller than him and 210% heavier than him: obviously I can't help but look down on him. :laughat:
jerk
by jerk
the issue with compacts for racing is not the extremes on either the low end or the high end; (a 50x11 is plenty big enough) but rather the missing middle gears. remember, compact used to be called "alpine gearing"; and that's exactly what is best for; going up and down really long sustained, steep climbs. for flat and rolling terrain; the jumps between the big and small chainring are too larg and require the cyclist to almost constantly remain in crossover gears when rolling along at a normal pace. pros will use the stuff in the mountains; but that's it.
not giving up my 42,
jerk
the jerk is always right!
the jerk thinks your stem is too short!
rruff
by rruff
jerk wrote:the jumps between the big and small chainring are too larg and require the cyclist to almost constantly remain in crossover gears when rolling along at a normal pace. pros will use the stuff in the mountains; but that's it.
Yep... crossover sucks... that's why I have a 48/36... but I'll consider putting on a 34 when I go to 10 speed.
Who cares what the pros use? I'd expect them to push slightly bigger gears than me...
maxxevv
by maxxevv
singlespeed wrote:Any idea where I can get that 36 tooth chainring? I'd like to change the 34 that came on my Time ASX.
I use the 36/50 on one of my set-ups. Wonderfully good!
You can try looking at TA or FSA, whichever is more readily available for you.
fatrat
by fatrat
One option I took, and which I haven't seen other do is to have a 38 or 39 inner 110 PCD and run 38/48 or 38/50 with a 12-25 or 11-23 cassette. Then when you go to the mountains it's just a 5 min job to swap out the inner chainring for a 34.
This way you get the low gears for the mountains but keep a nice tight gap at the front for normal use.
