Ultegra 8150 12 speed rear derailleur .. do they make a short cage now?
The general all-things Road forum!
billynyc
by billynyc
Hi
I'm using a 11-30 cassette on with the long cage, it looks hideous. Do they make a shorter cage version yet? I don't believe they did when I first got it plus I also originally had the 11-34 on there
Maddie
by Maddie
There is no short cage from Shimano for 8150 and 9250 derailleurs. I think your only choice is OSPW but they aren't smaller either.
ooo
by ooo
rd-r9250 has a shorter cage than rd-r8150
Dura-Ace cage length is about 94 mm, chain capacity is 37T.
Ultegra cage length is 100 mm, chain capacity is 39T.
https://handsonbike.blogspot.com/2023/09/12-speed-di2-rear-and-front-derailleur.html
pdlpsher1
by pdlpsher1
Shimano was able to shorten the 9250 cage since they lock out the two smallest cogs, which effectively increases the wrap capacity of the stock cage by 2 teeth. Putting the shorter 9250 cage on an Ultegra RD is probably OK as long as the cassette is kept to 11-30.
wltz
by wltz
On what kind of mushrooms must one be to accidentally, or intentionally, end up in small-small during normal riding? FWIW I modded my 8150 RD with a 9250 cage, and I'm running 54/39 with an 11-34 cassette without any issues.
billynyc
by billynyc
ooo wrote:
Fri Nov 08, 2024 8:44 pm
Thx!
billynyc
by billynyc
Thx!
wltz wrote:
Sat Nov 09, 2024 8:29 am
I'll try it out thanx
kofsw4
by kofsw4
wltz wrote:On what kind of mushrooms must one be to accidentally, or intentionally, end up in small-small during normal riding? FWIW I modded my 8150 RD with a 9250 cage, and I'm running 54/39 with an 11-34 cassette without any issues.
How much weight did swapping the cages save? Thinking about doing this too
Sent from my CPH2305 using Tapatalk
wltz
by wltz
74g vs 49g
kofsw4
by kofsw4
74g vs 49g
Thanks for the super fast reply. I'll give it a go Image
Ritxis
by Ritxis
Back in the day I mounted a 9100 cage that is shorter than the 9250 on an RD-8150 and without problems with a 32 at the back
Singlish
by Singlish
Ritxis wrote:
Mon Dec 02, 2024 9:42 am
Do you ever attempt running an 11-34 with this?
By the same logic, has anyone tried an 8150/9250 cage on 9150 to get a litle extra cassette capacity?
wltz
by wltz
FWIW, the 9150 RD clears 11-32 with the stock B-screw, iirc with at least 2 full turns to spare. I think it will clear 11-34 if you replace the DA B-screw with Ultegra, which is longer, but I guess your shifting in the highest gears will be compromised at this point. In fact, after replacing the 8050 RD (short cage) with the 9150 on my climbing bike, I also replaced my 11-32 Red cassette with an 11-30, because upshifting from 12t to 11t wasn't quite there.
P.S.: the bike has crazy short chain stays at 403mm, so this setup might work better with chain stays meeting the minimum 410 length specified by Shimano. I'm running Rotor Aldhu with a longer axle, which offsets my chainline by 2.5mm outboard and improves shifting in the small cogs.
