New Garmin Edge 1050, X50 etc.
The general all-things Road forum!
ivonenand
by ivonenand
Anyone tried the 1050 on the BMS Teammachine SLR01 / Roadmachine 01 ?
Philbar72
by Philbar72
my only concern is if we can edit the bike bell sound. that would be great...
TheBeautifulOne
by TheBeautifulOne
Just to confirm, 1050 is compatible with Frames and Gear long garmin computer holder for C68/V4RS (CC01 cockpit).
C68 - Campagnolo SR WRL - Bora WTO ultra
C64 - Campagnolo SR EPS - Bora WTO
Colnago Master - Campagnolo Potenza - Campagnolo Khamsin
SingleBe Desert Cat - Campagnolo Ekar - Shamal Carbon
cleanneon98
by cleanneon98
Anyone with a 1050 been using it for a while and have some feedback? Currently on a 1030 Plus and unsure if the new stuff is really worth it when it comes to actual usability.
Spinnekop
by Spinnekop
cleanneon98 wrote:
Fri Aug 16, 2024 2:28 pm
I have about 1000km now on mine.
Coming from the 840, the battery lasts about 3 times longer. But given the unit is 3 times bigger, it makes sense. :lol:
Getting around 30 hours on it before I charge it (about 30% battery life then left)
SW basically but the same.
I have used the bell a couple of times.
Screen quality is amazing. Very sharp and bright.
I love new more toned down tones for the Varia and lap etc.
No real bugs I have picked up. ANT+ thus far has been pretty solid.
"In my experience, there is only one motivation, and that is DESIRE.
No reason or principle contain it or stand against it........"
B0tt0mline
by B0tt0mline
I also got my one and really love the level of customization with mapdashboard, map fields and wind field.
Also liked the 1040, but hated the bugs.
Now I will compare the 1050 against the K3.
Colnago C68- Enve SES 4.5
S-Works Aethos - Enve SES 2.3
Enve Fray - Enve SES AR 4.5
Open MIN.D - Enve SES AR 4.5
Mosaic GT2-45 - Enve SES AR 3.4
Chinese Winter/Rain Bike
Brompton T-Line
Wahoo Kickr Bike
Jimmyrn85
by Jimmyrn85
Spinnekop wrote:
Fri Aug 16, 2024 3:06 pm
Interesting! What made you change from the 840, do you miss the buttons?
rollinslow
by rollinslow
Came from a 1030. Difference is a night/day improvement overall.
Jaisen
by Jaisen
Love it. I never thought I'd need a bell on a road racing bike, but I have been using it surpringly often. I paired it to my Shimano shifters. There is a slight lag before the bell rings but you get used to the timing after a while.
The screen is much brighter in low light environments which is nice, but in sun at midday with no clouds, the visibility can sometimes be tricky just like with the other models. The unit responsiveness is also slightly faster than the 1040 or 1030+. The UI update is also a welcome change. Overall no complaints. Also, finally the gradient lag is gone, though that was always a minor quibble.
milanv
by milanv
rollinslow wrote:
Fri Aug 16, 2024 10:31 pm
So 3 generations back, you have to note it. :wink:
1030/1030 Plus/1040/1050
usr
by usr
Like going from 1000 to 1040, yes, some change should be noticeable (there haven't been any 1010 or 1020, the 1000 was introduced as a contemporary of the 810 and its features trickled down to the 8x0 range became 820)
Jimmyrn85
by Jimmyrn85
I'm still rocking a 810 from 2013! Do you think I'll notice a difference? lol
usr
by usr
Will you notice being 63g slower? Probably not
robertoguinn
by robertoguinn
robertoguinn wrote:
Tue Jul 02, 2024 8:54 pm
pdlpsher1 wrote:
Thu Jun 27, 2024 5:45 am
If you already have a 1030/1040 and want to know if the 1050 will fit on your existing mount, just twist your GPS unit around upside down. If it fits then the 1050 will also fit. This tip was given by someone else on another forum.
Just got a 1050, and it does not fit my Emonda's Bontrager Aeolus RSL VR-C [included] mount. A backwards 1030 also does not fit, but a backwards 1040 does. K-Edge makes a mount for these bars, but theirs won't fit the 1050. I'm going to return the Garmin if I can't find a way to use it on my bike, since the computer and bars cost the same. I've contacted Trek & K-Edge, but not expecting much.
Anyone know of any other aftermarket options for these bars?
Really dissappointed that Garmin failed to consider all the 1-piece bar/stems out there with proprietary mounts when they changed the dimensions of their new computer. They could have made it ~1mm thicker so that it'd be ~1mm shorter with less bezel. Granted, it's already a brick of a bike computer, but they're stupid for failing to even consider the size issue. No way am I going to rubber band this thing on my stem either.
I've returned my 1050, and it made me happy that Garmin paid freight both ways. Maybe they'll notice the lost revenue from all the returns like mine and make new products compatible with existing hardware. I scored a 840 off a dude on Craigslist for $250 FTW.
Trek's mount for my bars is 2 pieces - a proprietary single screw part attached to the bars, with a GoPro style connector to the computer extension arm. It appears that this part is long enough per someone's post on the Garmin forum. There are many posts on that forum about how the stupid thing won't fit other bar/stems, which Garmin should pay attention to.
children trust me
Spinnekop
by Spinnekop
Jimmyrn85 wrote:
Fri Aug 16, 2024 9:58 pm
Basically, I am getting old. Hahahhaha.
:lol: :lol:
Some of the warning messages on the 840 became "suddenly" very unreadable.
I also do navigating every now and again, planning new routes etc. Street names on the map on the 840 and sometime where small singletracks split in a forest can be challenging to read on the fly.
Had to go to a bigger screen.
As for the buttons.
Never missed it. I alway paged with the DI2 remote buttons or the finger.
