New-ish Aeroad 2025
The general all-things Road forum!
tommay
by tommay
PaulJ wrote:
Mon Nov 11, 2024 10:37 am
Frame (almost) fully stripped down:
could you put it on a scale please?
BadBoyR
by BadBoyR
PaulJ wrote:My SLX 7 AXS turned up last week! It's already fully stripped apart from one stubborn BB cup - new BB tools arriving this week which should work better, beating press fit bearings out with a hammer never feels right, especially on a brand new frame, then I'll be building it back up with 12 speed Ultegra. With the price of groupsets at the moment it is far cheaper to get the SLX 7 and swap the groupset than it is to buy the SLX 8 with Ultegra aready on (minor wheel specs didn't concern me as I'll probably change the wheels anyway, and I didn't want the Shimano PM). I'll be weighing all frame parts, cockpit parts etc as part of the process.
Stock build:
I’ve done this too, had my first ride at weekend. Mine is 7.31kg with pedals and 50mm wheels
I’m waiting on delivery of my farsports 50/58 which are 55gm heavier than current wheels.
I upgraded the following ultegra parts with dura ace, calipers and rear cage. I’m still awaiting on my elilee cranks to drop some more weight.
Bike is fully wrapped with ridewrap and its dark forest. Size small, with 100mm stem and aero drops.
PaulJ
by PaulJ
BadBoyR wrote:
Mon Nov 11, 2024 11:36 am
Stock build:
That's a huge drop in weight with the groupset and wheel change, what do the 50mm wheels weigh? I've calculated mine should be ~7.6 without pedals on the DT Swiss with Ultegra groupset.
BadBoyR
by BadBoyR
Stock build:
Current wheels are farsports hyper in 50mm, 1222gm including tape. I’m using Favero dual assioma pedals.
PaulJ
by PaulJ
Here's the full breakdown of my SLX 7 AXS, for those interested. It weighed 8025g on my hanging scales, so 29.5g more than the seperate components - thats small enough to put down to the difference between the two scales or cumulative rounding errors etc.
gmarmar
by gmarmar
Hi, have anyone weighted Aeroad SLX Di2 size L?
Can you measure the height of the cockpit?
FuCH
by FuCH
gmarmar wrote:
Fri Nov 15, 2024 9:03 pm
Hi, I've measured it to 54.5mm. Maybe +-several mm. Stem 100mm.
FuCH
by FuCH
Hi everyone, let's talk tyres. 1100 Dicut come with 25F 28R Contis. They are superb, but quite slippery, had crashed and have no confidence on wet roads. Especially coming from Pirelly Cinturatto 32 tubeless. I am thinking about P Zero TLR speedwall 28F 30R (32?). Any recommendations? I am looking for more wet grip and protection.
It was already discussed that these wheels are optimized for 25, but to me it just feels not stable enough and the pressure would be high for tubeless.
By the way, a friend of mine have installed 35 on the back one and it works pretty well.
gmarmar
by gmarmar
What's the weight of Canyon Aeroad CF SLX Di2 (ultegra) size L in stock configuration?
NordicSal
by NordicSal
FuCH wrote:
Mon Nov 18, 2024 12:36 am
The GP5k All Season has possibly the best wet grip. I am thinking about running that in a 32c in the back and then the 29c 111 aero tire on the front - which apparently has even better wet grip.
FuCH
by FuCH
NordicSal wrote:
Mon Nov 18, 2024 5:23 pm
Great idea, will do my research on these 111 aero. Just realised these are tubeless ready. Just in case, what may be another fast but grippy tubeless option and which size would be recommended? It's not only butter smooth roads where I live, bricks, light gravel and winter now.
NordicSal
by NordicSal
Conti Terraspeed 35c if you want something rough, but I'd think 2x GP5k All Seasons in 32c would do
FuCH
by FuCH
What is the minimum valve length for tubeless tires on 50mm rims?
Thank you in advance
Swannie
by Swannie
i'm using 60mm muc off valves.
FuCH
by FuCH
Swannie wrote:
Thu Nov 21, 2024 7:43 pm
Can you please share a picture of the wheel with the valve?
