New-ish Aeroad 2025
The general all-things Road forum!
KalleWirsch
by KalleWirsch
German article comparing the Tarmac SL8, Madone SLR, Propel SL und Aeroad CFR
https://www.rennrad-news.de/news/4-supe ... eroad-cfr/
BadBoyR
by BadBoyR
What width are people running their aero drops? I’m not able to test mine out yet.
FuCH
by FuCH
BadBoyR wrote:
Thu Oct 24, 2024 7:56 pm
I went for the narrowest option available, as the drops felt as some gravel steer to me. So max aero and you get used to it pretty fast.
Another good thing about the bars - they do extend reach by 10mm. Exactly what I was missing about 100mm stem (size M).
KalleWirsch
by KalleWirsch
FuCH wrote:
Thu Oct 24, 2024 10:32 pm
...Another good thing about the bars - they do extend reach by 10mm. Exactly what I was missing about 100mm stem (size M).
Why do they extend the reach? Are the simply longer? Or because of the different position?
BadBoyR
by BadBoyR
Exactly, not read anywhere that the reach is extended. I’ve already changed from 90mm stem to 100mm stem as the reach is longer to my usual 54cm bike with 110 stem.
KalleWirsch
by KalleWirsch
BadBoyR wrote:
Fri Oct 25, 2024 11:16 am
... I’ve already changed from 90mm stem to 100mm stem as the reach is longer to my usual 54cm bike with 110 stem.
If the reach at the Aeroad is longer than on your usual bike, why did you extend it even further from 90mm to 100mm? Don´t understand that. Please explain.
PaulJ
by PaulJ
BadBoyR wrote:
Tue Oct 22, 2024 8:00 pm
PaulJ wrote:
BadBoyR wrote:
Fri Oct 18, 2024 10:47 pm
PaulJ wrote:I've no idea, the bike is on order, should be around a month so I can't check yet!
I’ll check and report back, my groupset hasn’t been delivered yet, so will have to wait a bit
Perfect, thank you!
Unfortunately, doesn’t fit.
That's a shame! Thanks for confirming.
BadBoyR
by BadBoyR
I extended to 100 not 110 to match my normal reach
macwatt
by macwatt
Hi
Any chance someone with a 2024 size S can measure reach from nose of saddle to stem and also to the top of the hoods please include your set back.
Thanks
FuCH
by FuCH
It was mentioned in the reviews online and see below:
BadBoyR
by BadBoyR
Yes, the box does state 10mm, however I don’t see it. I’ve placed the non aero drops for comparison and reach looks identical
tomtom
by tomtom
BadBoyR wrote:
Mon Oct 28, 2024 9:24 pm
I have measured it from the tip of my saddle towards the top of the hoods; because the shifters are more inwards than with the old bar-ends the distance is exactly the same but if you mount the shifters the same the distance (reach) will be longer
Ultimate CFR
Aeroad CFR
Grail CF
PedaleurPat
by PedaleurPat
tomtom wrote:
Tue Oct 29, 2024 3:22 pm
@tomtom, so does this mean that if I set the handlebars to 35cm, the reach with the AeroDrops remains the same, but if I set them to 37cm, the reach is 10mm longer?
FuCH
by FuCH
PedaleurPat wrote:
Mon Nov 04, 2024 1:50 pm
No, it's not about how wide or narrow you go, it's about the AeroDrops providing extra reach compared to stock drops
PaulJ
by PaulJ
My SLX 7 AXS turned up last week! It's already fully stripped apart from one stubborn BB cup - new BB tools arriving this week which should work better, beating press fit bearings out with a hammer never feels right, especially on a brand new frame, then I'll be building it back up with 12 speed Ultegra. With the price of groupsets at the moment it is far cheaper to get the SLX 7 and swap the groupset than it is to buy the SLX 8 with Ultegra aready on (minor wheel specs didn't concern me as I'll probably change the wheels anyway, and I didn't want the Shimano PM). I'll be weighing all frame parts, cockpit parts etc as part of the process.
Stock build:
Frame (almost) fully stripped down:
