2024 ENVE Fray
The general all-things Road forum!
hiasn
by hiasn
I live in the mountains and for me it's either 10% up or 10% down, so i decided to give the nex XPLR a try. i have been running it with 46 chainring in front for the last two months. now i plan to swith to 44t as i almost never use the 46-10 combination. however sometimes i could use a slightly lower gear on the uphills, as i often end up on smooth gravel roads for the last 100 vertical meters.
would definitely consider running a normal 1x setup up front and not the xplr as you have more choices of the chainrings. with the threat mount you are limited somewhere between 42 and 46. a 2x setup with 46-33 chainrings and 10-33 or even 10-36 casette would also do the job for me i guess- with a weight penalty of about 150 grams
Tarmacian wrote:
Wed Oct 30, 2024 11:53 pm
Super Nice! Im considering a similar build but still not sure about the groupset. It's gonna be Red XPLR or Red AXS e1. Did you consider 2x12 and what made you choose 1x13?
jayjay
by jayjay
Any owers of the SES AR one piece handlebar think that the handlebar could be stiffer? 🤔
pmprego
by pmprego
Does anyone know if a pathfinder 38c would fit in the rear using a 2x SRAM setup??
I know the official clearance is 38mm in a 2x setup and the pathfinders 38c measure 40mm on a 25mm internal wheel.
I assume clearing the front would be no problem.
jayjay
by jayjay
Had a problem with a slipping seat post, so Enve sent me a new one with a textured back. No problems so far :)
Sadly only available in 400mm length.
203g (+14g compared to my old 350mm version)
pmprego
by pmprego
jayjay wrote:
Thu Nov 28, 2024 1:33 pm
Only for the big boys (or girls) :mrgreen:
hansotto089
by hansotto089
https://r2-bike.com/CERAMICSPEED-Ball-B ... 7-mm-45-45
Just making sure - those are the correct ones?
jayjay
by jayjay
hansotto089 wrote:
Thu Nov 28, 2024 6:31 pm
These are the one I used. No problems so far after 1000km
hansotto089
by hansotto089
jayjay wrote:
Thu Nov 28, 2024 9:46 pm
Same for upper and lower, right?
If I only want to upgrade one, probably the lower one?
jayjay
by jayjay
hansotto089 wrote:
Thu Nov 28, 2024 11:02 pm
Correct
MementoMori
by MementoMori
No charge for the replacement?
Thanks!
MementoMori
by MementoMori
jayjay wrote:
Wed Nov 06, 2024 6:19 pm
No idea on the stiffness, have yet to mount.
It seems there are two versions, the bars itself are identical but the difference lies in the way the computer mount connects to the unit.
On the Enve website I can find the version below:
Screenshot 2024-12-02 125025.png (55.19 KiB) Viewed 451 times
My bars however show a different assembly:
And of course, in my attempt to finally find a solution for my Garmin 1050 challenge, I ordered a mount via Frames and Gear which only works with the option that Enve shows on their website.
From what I've been told, my version is the most recent version.
For now, still no solution for the Garmin 1050. I'm using a Ravemen light in between for now until I can find a final solution.
jayjay
by jayjay
MementoMori wrote:
Mon Dec 02, 2024 12:45 pm
https://s20.directupload.net/images/use ... ufyawa.jpg
Thanks!
Nope :)
jayjay
by jayjay
MementoMori wrote:
Mon Dec 02, 2024 12:52 pm
Looks like the same computer mount as they use for the Aero Pro one-piece
MementoMori
by MementoMori
Yep, that's the one. Too short however for my 1050. :X
jayjay
by jayjay
MementoMori wrote:
Mon Dec 02, 2024 3:21 pm
Do you know if a 1040 would fit?
