So, errr, why didn't you ask for either of those things?
2024 product release rumors
360-420 x 90-150 is a lot of options for a 1-piece solution, and I'm assuming it's 10deg like seemingly every other bar out there.
These brands should really consider doing a streamlined 2-piece solution and also offer -7/-12/-17deg options.
Look similar to the Rex Black Diamond Wax in concept... I wonder if Silca took a similar approachJaisen wrote: ↑Sat Feb 17, 2024 1:15 amLooks like there will be a new Silca wax coming Feb 20th.
https://www.youtube.com/watch?v=Hfn5TDyIfOc
If it can do a couple thousand kms in between applications and endure through rain, that could be nice. I wonder what they have in store.
which means a typical fuxking overpriced stuff with a Slica stamp.TobinHatesYou wrote: ↑Sat Feb 17, 2024 7:32 amJaisen wrote: ↑Sat Feb 17, 2024 1:15 amLooks like there will be a new Silca wax coming Feb 20th.
Not a new wax. It's a Silca branded heating vessel.
Silca are champions of taking products from other domains, repackaging and branding it for cycling and then charging a hefty premium.
Not a crticism of their products which are in general very good, but their marketting is even better...
Yes this!TobinHatesYou wrote: ↑Sat Feb 17, 2024 10:15 amThese brands should really consider doing a streamlined 2-piece solution and also offer -7/-12/-17deg options.
- Contact:
New Cervelo P5 https://escapecollective.com/spotted-vi ... a-algarve/
Those angle adjustable pads look quite funky if they're a stock feature.ronanmclaughlin wrote: ↑Sun Feb 18, 2024 9:03 amNew Cervelo P5 https://escapecollective.com/spotted-vi ... a-algarve/
You are absolutely right..! A neat 2-piece option would be the best solution, and a 12.deg would in my own case be spot on! And yes - the Polymer cockpit is a 10.deg wich to me is ok - much better than 6/7.deg.TobinHatesYou wrote: ↑Sat Feb 17, 2024 10:15 am360-420 x 90-150 is a lot of options for a 1-piece solution, and I'm assuming it's 10deg like seemingly every other bar out there.
Look is having something going on with their cockpit, only flaw is the measures - stem to short bar to wide, but if they had more options we are close to perfect. Do you have knowledge on any other brands who's working on anything similar?
Haven't seen the other images, but frankly that looks like there is a strap but that it has not been correctly setup/adjusted.
- Michael
