Red AXS E1 (Where is New SRAM Red)
The general all-things Road forum!
gospastic
by gospastic
hannawald wrote:
Tue Nov 19, 2024 2:42 pm
Does everybody use recommended Paceline X rotors? At 132g for 160mm rotor I am tempted to save more than 20g per rotor and use Shimano XT RT-MT800. Any reason for taking Paceline X besides brand purity? Will they be stronger, more silent...? Saving weight is nice but braking is important so checking with you... Thanks!
I don't think they function any differently than the previous Centerline XR rotors. You can save 70g by going with Galfers. I have switched to them on all bikes and like them a lot.
HannibalLecter
by HannibalLecter
gospastic wrote:
Tue Nov 19, 2024 5:30 pm
I switched to Galfers and I saved 110 grams and 50% of the braking power. When half of the disc is holes that's what you get. But they are still adequate
gospastic
by gospastic
HannibalLecter wrote:
Tue Nov 19, 2024 6:42 pm
I haven't experienced that. But okay
Nickldn
by Nickldn
gospastic wrote:
Tue Nov 19, 2024 6:49 pm
I have to agree, having used Campy, Centreline and Galfer rotors with Red I do not detect any decrease in braking power from the lighter Galfers.
I do suspect Galfers will be able to absorb less heat than the other two rotors due to reduced mass, but that only comes into play under quite extreme usage, e.g. alpine descents. Under everyday braking Galfers provide as much power as the others.
TobinHatesYou
by TobinHatesYou
My Galfers make a patterned noise after they reach a certain temperature on steep, technical descents. They also require the use of a shim when used with externally notched lockrings.
bikeboy1tr
by bikeboy1tr
velomane wrote:
Sun Nov 17, 2024 4:42 am
If anyone sees a Black Friday deal on Red groups, please post it here.
https://www.thebikezone.com/product/sra ... TEQAvD_BwE
viewtopic.php?f=10&t=154188
2018 Colnago V2R Rim Brake
2019 Colnago V2R Disc Brake
pushpush
by pushpush
TobinHatesYou wrote:
Wed Nov 20, 2024 1:47 am
Can you please elaborate on why/when to use a shim? I don't think I understand how an external vs internal notched lockring would make a difference.
TobinHatesYou
by TobinHatesYou
pushpush wrote:
Sat Nov 30, 2024 7:38 am
The Galfer “Road Wave” centerlock rotors are natively 6-bolt. A shim is necessary when you use a lockring that is larger in diameter than the 6-bolt adapter.
pushpush
by pushpush
Ah! That makes sense. Thank you.
Galfer supply an external notch lockring with the rotors. I guess it already has a shim or is just small enough? I never thought twice about it until now.
TobinHatesYou
by TobinHatesYou
pushpush wrote:
Sun Dec 01, 2024 5:36 am
It comes with the shim. Most internally notched lockrings are small enough and don't need the shim. Some like the ENVE lockrings would need a shim.
HannibalLecter
by HannibalLecter
A question, can anyone verify that the screws that hold the E1 calipers together are titanium or not? I think they are but I'm not sure
HannibalLecter
by HannibalLecter
Sun Dec 01, 2024 6:12 am
I think this shim is deformable and is there to act as a mean of retaining so it doesn't get loose, not as a spacer. And many other lockrings, internal or external have it. Actually I think all have it
HannibalLecter
by HannibalLecter
Sun Dec 01, 2024 2:13 pm
Never mind, per Srams parts catalog they are titanium
eins4eins
by eins4eins
Installed E1 yesterday and while the levers are awesome, the calipers look kind of cheap.
The two halfs of the front caliper don't match and have an offset. Rear caliper ist better, but not great as well.
Is it normal?
HannibalLecter
by HannibalLecter
eins4eins wrote:
Sun Dec 01, 2024 3:09 pm
Is it normal?
Yes it is, mine are also like that. This is how they come out of forging probably and as this is not a critical dimension they leave it like that
