The general all-things Road forum!
TobinHatesYou
by TobinHatesYou on Sun Dec 01, 2024 7:20 pm
HannibalLecter wrote: ↑Sun Dec 01, 2024 2:17 pm
TobinHatesYou wrote: ↑Sun Dec 01, 2024 6:12 am
pushpush wrote: ↑Sun Dec 01, 2024 5:36 am
Ah! That makes sense. Thank you.
Galfer supply an external notch lockring with the rotors. I guess it already has a shim or is just small enough? I never thought twice about it until now.
It comes with the shim. Most internally notched lockrings are small enough and don't need the shim. Some like the ENVE lockrings would need a shim.
I think this shim is deformable and is there to act as a mean of retaining so it doesn't get loose, not as a spacer. And many other lockrings, internal or external have it. Actually I think all have it
It’s is not simply a crush washer like on other lockrings, it’s thicker than that.
pushpush
by pushpush on Mon Dec 02, 2024 12:51 am
I'm having a hell of a time eliminating pad rub on my front E1 caliper. Pistons are fully seated. Using stock supplied SRAM pads. I tried Galfer Road Wave, Catalyst Pro, and Shimano discs. The Shimano discs are a hair bit narrower than the others. I spent a bunch of time truing them. The pads continue to rub for a few minutes AFTER applying pressure to the system. It is like the pistons take way too long to retract. I did a full bleed. I tried removing a small amount of fluid from the system. Not sure what else to do.
The e1 rear caliper with the same pads and discs has no problem. Previous Red D1 calipers had tons of clearance and required no fiddling. Is it possible there is something wrong with this specific caliper itself? I can request a replacement.
The shifters are night and day better than the previous generation.
X5SAE
by X5SAE on Mon Dec 02, 2024 9:37 am
pushpush wrote: ↑Mon Dec 02, 2024 12:51 am
Are you sure your fork brake mounts are square? They might need a bit of facing. Weird that D1 was better...
Road
Cube Agree C:62 SLT 2021 (frame+fork) DA 9270 6.9x kg - ride-ready 7.25 kg w/pedals, cages, sensors, Wahoo mount
Gravel
Velobuild GF-002 Force AXS 7.5 kg, ride-ready 7.775 kg w/200 ml Stan‘s, pedals, cages, sensors, Wahoo/Cateye mounts
pushpush
by pushpush on Tue Dec 03, 2024 4:49 am
HannibalLecter wrote: ↑Mon Dec 02, 2024 9:38 am
Usually I find that sram have enough pad clearance to work with. Id probably sent it back.
Edit; does it constantly rub ? Maybe its a disc issue
Tried 3 different discs with the same result. The shimano disc being the thinnest works the best, but that isn't saying a whole lot. The replacement is back-ordered for a couple of weeks but it was no problem getting an exchange lined up. The fact that the rear caliper works as expected makes me think the front is somehow defective. We'll see what happens.
On a positive note, now all my brake rotors are nice and straight!
kervelo
by kervelo on Tue Dec 03, 2024 6:26 am
Did you try the procedures described in the troubleshooting part of the manual?
https://docs.sram.com/en-US/publication ... leshooting
HannibalLecter
by HannibalLecter on Tue Dec 03, 2024 9:59 am
pushpush wrote: ↑Tue Dec 03, 2024 4:49 am
It's just a sticky piston then, nothing new under the sun. You could bother to free it up but I wouldn't
robeambro
by robeambro on Sun Dec 08, 2024 11:42 am
Looking to possibly fit Red E1 shifters, brakes and derailleurs to a build. In order to take advantage of better FD shifting, does one also need new Red E1 rings, or would any other (say, Red D1, Force D2) work just as well?
HannibalLecter
by HannibalLecter on Sun Dec 08, 2024 1:27 pm
robeambro wrote: ↑Sun Dec 08, 2024 11:42 am
No, tye technology on these parts is exactly the same
robeambro
by robeambro on Sun Dec 08, 2024 4:17 pm
HannibalLecter wrote: ↑Sun Dec 08, 2024 1:27 pm
Thanks - that's reassuring.
Tpduke112
by Tpduke112 on Mon Dec 09, 2024 12:28 am
I just want to say it's impressive how much smoother and quicker E1 shifts than D1. I don't think I realized how much I change my cadence to make sure I the shifts are smooth or that I don't drop on my D1 bike. I don't even think about it at all on E1. Shifts under load with little fuss.
‘22 Bianchi Oltre XR4 Disc - Fast Race
‘25 SWorks SL8 RTP - Climby Race
‘24 Specialized Crux Pro - Dirty Race
‘22 Bianchi Sprint - Practice Race
‘17 Bianchi Pista Sei Giorni - Dont Race
spartan
by spartan on Mon Dec 09, 2024 3:27 am
any timeframe when rival/force will get a refresh next year with new levers/brakes
Current Rides:
2025 Giant Propel Advanced SL 9270
2023 Tarmac SL7 Di2 9270
ex 2019 S-works SL6
ex 2018 Trek Madone SLR Disc
ex 2016 Giant TCRAdvanced Sl
ex 2012 Trek Madone7
hannawald
by hannawald on Wed Dec 11, 2024 8:31 pm
Hi, I am new to Sram. I have bought Red shifter/caliper set and it comes as one piece. I can see "dream build" videos where they make internal routing and there is some silver ending. They also position shifters without being them connected to the hose... what is the trick you can do this without the oil coming out of the shifter/hose? What plugs can I buy for this? Thanks!
HannibalLecter
by HannibalLecter on Wed Dec 11, 2024 9:14 pm
hannawald wrote: ↑Wed Dec 11, 2024 8:31 pm
How's that silver thing you talking about look like?
Do you mean a nipple? For sram you need special sram ripples, with threads and special corresponding red aluminium olives. Not much oil will come off of your hoses, unless you want them a lot. However plugs are useless, cause you will definitely need to cut the hoses. From the sound of it you are not very familiar with the details of this job and its quite challenging, especially if you are a novice. And you seem to have an integrated bike as well.
I'd leave a shop do it or really study the task. You can also leave the old hoses in probably. Either way you will need a bleeding.
Uberflo
by Uberflo on Wed Dec 11, 2024 9:45 pm
... but only if there is dot in there.
You need SRAM Stealth-a-majig for connecting the hoses to the shifter. Look at the the SRAM YouTube channel. There is a video for every step, including hose shortening and system bleed.
