Specialized S-Works Tarmac SL8
The general all-things Road forum!
SilverSteve
by SilverSteve
Charlie69 wrote:
Sun Dec 08, 2024 4:51 pm
SilverSteve wrote:
Wed Nov 06, 2024 9:07 pm
Charlie69 wrote:
Wed Nov 06, 2024 7:45 pm
I'm changing my cranks to SRAM red axs e1 dub.... can anyone recommend a decent dub bsa compatible bottom bracket without breaking the bank. From what I hear the sram dub bb iOS not very good.
I bought this one from Bikone.
https://www.bikone.com/producto/dctech-bsa-68-73mm-dub/
I have not ridden it yet. Still building up my bike. It is very well constructed though and I like the extended sleeve design.
Did you fit this Bottom bracket yet?... and if so what do you think of it and what spacers did you need on DS and NDS.... thanks.
@Charlie69 I installed the BB and only have about a 100 miles on it. So far it's been good.
Charlie69
by Charlie69
SilverSteve wrote:
Mon Dec 09, 2024 4:49 am
Thanks very much... have you any idea what spacers I need to fit a SRAM red E1 chainset to my Sl8 using this bottom bracket ?
SilverSteve
by SilverSteve
Charlie69 wrote:
Mon Dec 09, 2024 1:19 pm
@Charlie69 you can find the spacer specifications on SRAM's website.
https://docs.sram.com/en-US/publication ... acer-chart
Charlie69
by Charlie69
Thanks very much
Upcountry
by Upcountry
A new frameset color, and I have to say, it might be my favorite yet... again, I love the minimal branding, without the "specialized" on the fork and chainstay.
paulbike
by paulbike
Upcountry wrote:
Wed Dec 11, 2024 2:50 pm
I want it. I bet it's going to look amazing in person.
ichobi
by ichobi
Without that s-works logomark would have been even better. Their 2023/24 Dune Gloss color (almost invisible S-Works) on the white marble gloss frame is stunning. Almost looks like a custom bike.
pamoreira
by pamoreira
ichobi wrote:
Thu Dec 12, 2024 9:07 am
Having one in that color, I would have to agree :D I get a lot of "what bike is that?" questions from other cyclists since there's barely any logo visible on it and the paintwork looks out of the ordinary.
cpark
by cpark
Ol3Tarmac wrote:
Thu Jul 18, 2024 7:37 pm
proffate wrote:
Wed Jul 17, 2024 11:29 pm
Ol3Tarmac wrote:
Wed Jul 17, 2024 7:09 pm
StefanBRNRD wrote:
Sat Jul 13, 2024 7:46 am
I hear you.... 7.2 for a
Project Black 56, 400x100
DA with SRM Look Carbon, DA pedals
Ronin Mirror, S-Works Cage, Wahoo Mount
Rapide Team with Conti S TR (28/30 TL)
Despite the wide tires I was hoping to be < 7.0
Same here ....
7.1kg without computer, lights, Bidon
still looking for an explaination
Size 54, 420x110
Wahoo Powrlink dual pedals
S-works Mirror
3d print wahoo/garmin mounts
Bora Ultra WTO with 30mm strada bianca tires (TPU tubes)
By changing the tires i could easily drop 100g, however beside the tires there is not much room for weight improvement and it comes at the price of loosing puncture resistance and comfort.
listed weight of 56cm da di2 sworks is 6620g
you added 276g pedals, that leaves about 200g for cages and mounts, differences in cockpit dimensions + stack of spacers, bar tape.
What weight were you expecting?
I did almost the same plausibility check
The frame size is smaller. Maybe it gets offset by my rather large cockpit dimensions and stack of spacers or is there more potential?
The pedals are definetely adding weight. However, the wheelset should be almost 200g lighter than the stock wheels (clx ii).
The groupset maybe is heavier than the di2. Disregarding this position for a stock bike (56) with the mentioned modifications, a system weight of approx. 6'690g before mounts should result. Another 100g can be added for the tires and again also for said mounts. This still leaves approx. 200g of "non" explained system weight in my case.
So I was expecting to be clearly below 7kg.
I apologize in advance if someone already pointed this out. It looks like the Strada tire is about 100 grams heavier per tire vs stock Specialized tire, so that maybe the 200g delta you are looking for.
justinfoxphotos
by justinfoxphotos
New Bike Day!
MagCAD computer mount.
Size 52, 6.85kg's as pictured but now lighter with Galfer rotors + Absolute Black lockrings at 6.75kg's.
Nervousness, paranoia, anxiety, buyers remorse, just some of the things I've been feeling the past few days, but really happy to say that my SL8 got to me earlier today without issues!
A sticker on the bike suggests the bike was born on the 8th of May 2024 (nice!). The paint is amazing in real life. So much detail up close.
The bike came with a Roval computer mount (I have one on my Allez, it's a solid unit). I didn't know it was going to come with one and had ordered a 3D printed MagCAD computer mount. The Roval mount weighs in at 52g, and the MagCAD weighs in at 18g so I've decided to remove the Roval and install the MagCAD one.
Owning and dialling in the fit on my SL6 (also a size 52) was a blessing as it's made setting up the SL8 a breeze. The SL8 came with a 15mm offset seatpost which I've replaced with an S-Works 0 offset seatpost and the bike setup is now pretty close to my SL6 (5mm longer reach as the Roval cockpit on my SL8 has a 115mm stem).
Sadly the 0mm offset seatpost is pretty porky at 173g (the 15mm setback post was 141g). I'll most likely look into either a Hylix, or Darimo, or Alpitude seatpost at some point down the line, but for now this heavy and weird looking 0 setback seatpost is doing it's job.
The S-Works Power with Mirror saddle looks super wide and it's heavy at 203g. I've got to at least test it out though, who knows? It may kill me with comfort.
Also moved my Galfer rotors off my Allez Sprint. Replaced the rear SRAM Red 160mm with the Galfer 140mm and also installed Absolute Black Lockrings and Graphen Pads (same weight as the SRAM pads at 20g/pair).
Issues: I've read of a lot of owners with a gap between the headset dust cover and frame, and yup, mine has it. I've also read of people complaining about the top cap bolt not fitting flush, and yup, mine has that too, but worst of all I've read of SL8 owners noticing that their front wheel isn't dead centre, and happy to say I do not have this issue (phew!).
Locked in to go for a ride tomorrow morning. Can't wait!
SPECS:
2025 S-Works Tarmac SL8 (Size 52)
Gloss Dove Grey / Silver Dust Blurred Impasto / Black Pearl
Brake Rotors: Galfer E1 160mm/140mm (97g/79g)
Brake Pads: Absolute Black Graphen (40g)
Shift Levers: SRAM RED E1
Derailleurs: SRAM RED E1
Cassette: SRAM RED 10-33t
Chain: SRAM RED E1
Crankset: SRAM RED E1 with Power Meter 165mm
Chainrings: SRAM Red E1 48/35
Pedals: Xpedo Thrust SL Titanium (165g)
Bottom Bracket: SRAM DUB BSA 68
Front Wheel: Roval Rapide CLX II 51mm
Rear Wheel: Roval Rapide CLX II 60mm
Tyres: S-works Turbo Rapidair 2BR 700x26mm
Inner Tubes: Specialized Turbo Ultralight 60mm Front, 80mm Rear
Lockrings: Absolute Black (10g)
Stem: Roval Rapide Cockpit 380mm/115mm
Tape: Supacaz Super Sticky Kush
Saddle: Specialized S-Works Power with Mirror (203g)
Seatpost: S-Works 0mm offset (173g)
Computer Mount: MagCAD (18g)
Bottle Cage: S-Works Carbon Rib Cage III (24g)
WEIGHT: 6.75kg
ichobi
by ichobi
Stunning color and build!
This one you bought a completed bike right? Notice there is no this particular colorway for the 2025 frameset option.
justinfoxphotos
by justinfoxphotos
ichobi wrote:
Fri Dec 13, 2024 11:27 am
Yes bought as a complete. When I was finally ready to buy an SL8 all the size 52 framesets were sold out, so my only option was to buy a complete with Dura-Ace. I was willing to settle for Dura-Ace over Red E1 but on hearing that I prefered Red over Dura-Ace the shop I bought the bike from suggested that they could move over a full Red E1 groupset from a size 49 SL8 at no additional cost (in their words "you're buying a premium bike and with that comes premium service"!). Winning as I love Red E1 and I also get shorter 165mm cranks AND they also let me choose my 380/115mm Roval Rapide cockpit at no additional cost.
CrankAddictsRich wrote:
Fri Dec 13, 2024 2:40 pm
Beautiful!!!!! WOW! I want my SL8 so bad now.
Cheers Rich! It better be damn good considering how much hype it has and how expensive it is. Visually I think it looks a bit odd in pictures but absolutely AMAZING in real life. I've watched many hours of people riding SL8's, and have so many saved SL8 photos, but man, that speed sniffer headtube in real life is nothing at all like the pictures. It's far from bulky, it's actually quite narrow front on, and it looks super aero. The seatube is crazy aero too, and the quality of the paint is awesome (and very hard to capture in photographs).
I'm super torn between leaving it as is, dead stock and fully functional vs. shaving grams off it. I've taken off the rear 160mm rotor and replaced it with a 140mm Galfer and already I think the Galfers (both front and back) just look so much weaker (the Red rotors with their black centres actually tie in with the bike more).
Ultimately I know what I need to do, and that's just to leave it as is for now and just ride the hell out of it!
ilco
by ilco
Hello,
I've designed a small 5.6g support for Airtag inside / below my seatpost.
https://www.thingiverse.com/thing:6872315
Hope you like it.
justinfoxphotos
by justinfoxphotos
Only just saw that the Smooth Operator got his own 1 of 1 custom SL8. 8)
