Carbon paste - what do you use and what works?
eucalyptus
by eucalyptus
Weightweenies = lightweight stuff = requires the best carbon paste for low torque bolts
What carbon paste have you found to be the best?
I use Motorex carbon paste right now which I found to be working really good. I also know Muc off pink carbon paste is excellent for difficult seatpost.
Tried Fenwick from Wiggle but it was not as good especially not on high end parts requiring lower torque on the bolts.
Anyone who has experience with Effetto Carbogrip? Either spray or 3ml resin packs.
https://www.effettomariposa.eu/products ... mbly-resin
I bought the Effetto but yet to try it, would like to hear your opinions of you have tried it :)
AJS914
by AJS914
You use carbon paste on bolts? Carbon paste is just grease with some grit inside to create friction.
I wouldn't be wooed by overpriced grease like carbogrip or most products like these marketed to bicycle nerds.
I bought a tube of Mobile 1 synthetic grease for like $3 around 20 years ago and I'm still using it. I think the same tube is $8 today. You can find it in the automotive supply area. I have a small tube of Park carbon paste which I use for surfaces that might slip - like seatposts or handlebars and that is lasting forever since my stable of 4 bikes doesn't need it very often.
nickf
by nickf
I have been using Finish Line Fiber Grip for years. Works great. No issues with Extralight stems, AX stems, Darimo post. Thats all we would use at the shop and never had customers with issues.
MikeD
by MikeD
Isn't there carbon paste without grit? Grit will ruin surface finish. I think Ritchey may make one, maybe Tackx.
unclearv
by unclearv
MikeD wrote:
Tue Mar 28, 2023 7:27 pm
Motorex
Hexsense
by Hexsense
unclearv wrote:
Tue Mar 28, 2023 11:39 pm
Motorex
That, or Effetto Mariposa Carbogrip.
If you can, buy the blister version. I bought the spray bottle and it's annoying to occasionally use it. Because it clog up the nozzle a lot after sometime resting no used.
TobinHatesYou
by TobinHatesYou
Motorex.
