It immediately began making a lot of noise at 9/3 crank rotation when in the small chainring
It does not make any noise on the big ring (in any gear) but does in all gears on the small chainring
The noise occurs when the chain peels away from the small chainring at the bottom. I can see/feel the noise and small clunk as each link rolls off the chainring when I put pressure on the crank. It looks like the link is sticking to the chainring for a moment rather than releasing immediately.
- I pulled the crank and re-torqued the BB
I reinstalled and torqued the crank
I confirmed the chain and quick link were installed correctly
I lubed the chain again and cleaned the chainrings
I reversed the direction of the chain (still flattop facing out)
