Cybrei carbon crankset & carbon chainrings
The general all-things Road forum!
StiffWeenies
by StiffWeenies
Lengths: 162.5mm, 165mm, 167.5mm, 170mm, 172.5mm, 175mm
Axle diameter: Alloy 29mm (DUB)
Q-Factor: 148mm
Chainline: 44mm (2x)
crank interface: Cinch
sans-PM spider: 4-arm Alloy (40g)
sans-PM weight: 29mm axle (320g) not incl. spider
2x Carbon chainrings: 50/34 (127g), 52/36 (134g), 54/38 (141g)
2x Alloy chainrings: 50/34 (148g), 52/36 (156g), 54/38 (164g)
Notes:
Despite the visual similarities, Cybrei is NOT made by the same factory as Elilee
The carbon chainrings appear to be Rotor Qarbon style rather than Carbon-Ti style
photos courtesy of Cybrei, cannondale_7om and 弘達自轉車
Maddie
by Maddie
Fantastic! Thanks for posting this stuff that we would probably never see otherwise.
Gesendet von meinem SM-G973U1 mit Tapatalk
robertonavaz
by robertonavaz
StiffWeenies wrote:Cybrei carbon crankset
Q-Factor: 148mm
Notes:
How much less than a red bb30 crankset?
Edit: something like 130-150gr for crankset + spider
Inviato dal mio iPhone utilizzando Tapatalk
StiffWeenies
by StiffWeenies
robertonavaz wrote:
Mon Feb 13, 2023 8:56 pm
The prices should all be listed on their website linked above. Do note that although everything is in USD, they don't have the payment processing set up yet for international orders. This is a very young brand, not even launched in China yet.
C36
by C36
Thanks for sharing, saw it on a Chinese forum where you use to post.
Interesting, like were skypivot (that is back according to IG) and eliee were/could be. Still a bit thin so far in terms credentials or technical details and performance. Would be great if they could contact fairewheel who is running a crankset stiffness test as we speak.
StiffWeenies
by StiffWeenies
C36 wrote:
Mon Feb 13, 2023 10:05 pm
Interesting, like were skypivot (that is back according to IG) and eliee were/could be but a bit thin so far in terms of technical work and performance. Would be great if they could contact fairewheel who is running a crankset stiffness test as we speak.
Is Fair Wheel running a new test? their last one was published ages ago
C36
by C36
They are!
cannondale7om
by cannondale7om
The glossy crank and carbon chainring looks really good under the sunlight! :beerchug:
Pyotrump
by Pyotrump
Is non drive side arm detachable? It seems it's using cinch type spline. I just want to use longer axle for my pf30a 83 bb.
cannondale7om
by cannondale7om
Pyotrump wrote:
Tue Feb 14, 2023 3:06 am
Non-drive side arm is not detachable. It is a dub axle so you can easily buy a Sram pf30a-83 to dub BB to make it compatible.
RDY
by RDY
cannondale7om wrote:
Tue Feb 14, 2023 2:56 am
Which PM is that?
Maddie
by Maddie
RDY wrote:
Tue Feb 14, 2023 10:51 am
Which PM is that?
XCadey
theyoungconnoisseur
by theyoungconnoisseur
will this fit my new madone slr with ultegra crankset? is it a direct swap? or do I need to do something with removing and replacing a bottom bracket?
frnchy
by frnchy
theyoungconnoisseur wrote:
Sat May 06, 2023 12:16 am
It's a DUB axle (28.99 mm) so you would need a new bottom bracket because your Ultegra crankset has a 24 mm axle.
Unrelated, but the crankarms and complete cranks are available through China Cycling's new website (https://www.pandapodium.cc/product/cybr ... -assembly/) ; I'm not sure if the price includes import duties but if it does then they seem like a merely OK deal, as the arms are only ~20g lighter than a set of SRAM Red crankarms but cost ~$50 more. If the price doesn't include import costs then I don't see a reason to get these over the Red crankarms.
alanyu
by alanyu
The crank is a rebranded Neutron, which had a lot of failure.
Did they improve the design? Let time tell.
