Definitely a nice gravel setup, but I do wonder about the performance of the regular Red medium cage rd on cassettes with cogs bigger than 32. I know it can be done, but any time I have tried to push rear derailleurs beyond the recommend largest cog, I end up with some spot on the cassette that hesitates to shift, or a ticking noise in certain gears. I can tune it out of one spot, but it will reappear in another. Have you had perfect operation with a 34 tooth cassette? I will however give a strong vote for the Sram mtb rear derailleurs. I have one Red 22 setup with 11-36 and a XX long cage rd. Flawless shifting and still very light. Now impossible to find, but lower level compatible Sram mtb rd's are still around.Hexsense wrote: ↑Fri Feb 03, 2023 8:51 pmSram 22 shifters with right side converted.
Gearloop 44/28 front chainrings, 2x. -- this is for a gravel bike. If you use road bike then keep regular 50/34 or 52/36.
Shimano GRX Front derailleur in my case to cope with the 44/28 front rings. (yes, it works with Sram left shifter too)
Ultegra 12 speed 11-30 cassette. -- 11-34 would work too.
Sram long cage 11 speed road rd.
Find me a lighter groupset with tighter gearing...
Lightest 12s Disc groupset in 2023
[/quote]
[/quote]
Yes do agree with you. It would be the lightest option for gravel to go with
Xx1 11speed mtb der (240) with pulley replaced (10g off)
Ratio cable fin
Sram red 22 hydro shifter
12 cassette
These are better than TRP HY/RD or Origin-8?CampagYOLO wrote: ↑Fri Feb 03, 2023 12:52 amJuin Tech GT-F is where it's at, they're almost as good as a proper hydraulic set up but 150-200g lighter.
Luckily for me, Pilo makes a slightly longer RD hanger for my bikes and a WiFli RD would have no issue with a 10-33t or 11-34t.
Never used the Origin-8 brakes but definitely more modulation and stopping power than a HY/RD. They also look a lot better and are lighter.markdjr wrote: ↑Sat Feb 04, 2023 4:59 amThese are better than TRP HY/RD or Origin-8?CampagYOLO wrote: ↑Fri Feb 03, 2023 12:52 amJuin Tech GT-F is where it's at, they're almost as good as a proper hydraulic set up but 150-200g lighter.pmprego wrote: ↑Thu Feb 02, 2023 11:30 pmIt's a safe bet.TobinHatesYou wrote: ↑Thu Feb 02, 2023 11:29 pm
Not sure what the goto mech calipers are these days, Juintech F1 hybrids?
I'd say it depends. I've got my GT-F's set up on an externally routed bike with compressionless housing. No tight bends anywhere to affect performance.Hexsense wrote: ↑Fri Feb 03, 2023 8:46 pmHuh? Is it that good?CampagYOLO wrote: ↑Fri Feb 03, 2023 12:52 amJuin Tech GT-F is where it's at, they're almost as good as a proper hydraulic set up but 150-200g lighter.
My Juin Tech F1 is a bit underwhelming vs my Ultegra Di2 hydraulic on another bike.
So I'm wondering about upgrading it to either proper hydraulic, or Juintech GT-F.
On an internally routed bike I'd be tempted to go for the full hydraulic set up if cost isn't an issue.
Juin tech F1 are 2 pots, the GT are 4 pots so with more pistons and braking surface they will do betterHexsense wrote: Huh? Is it that good?
Sent from my Pixel 6 using Tapatalk
Only thing I don't like about this is that it doesn't show Bottom Bracket weight in the total. Given that Campy options have bearings integrated in the crankset (and only need 35g cup in addition), but other require full bottom bracket with bearings. I would adjust by 60-ish grams everything in favor of campy.dalord774 wrote: ↑Fri Feb 03, 2023 5:49 amNot much has happened since 22, has it?
https://ccache.cc/blogs/newsroom/2022-r ... comparison
I wonder if there is anything else they forgot since they forgot such an obvious one already
#RETIRED# Lynskey “the Do-it-all Helix” :https://tinyurl.com/bdmb5y24
But if your Red BB30 crank is installed in a BB30 frame, than all your bb consists of just two cartridge bearings and dust covers - a crank/BB combo that is tough to beat. Use ceramic bearings and it's even lighter.Yoln wrote: ↑Sat Feb 18, 2023 11:04 pmOnly thing I don't like about this is that it doesn't show Bottom Bracket weight in the total. Given that Campy options have bearings integrated in the crankset (and only need 35g cup in addition), but other require full bottom bracket with bearings. I would adjust by 60-ish grams everything in favor of campy.dalord774 wrote: ↑Fri Feb 03, 2023 5:49 amNot much has happened since 22, has it?
Anyone know of a creative way to get a mineral oil hydraulic lever working with a 12 speed rear derailleur? I'm flexible with component spec (beggars can't be choosers), but ideal setup would be Dura Ace levers with a XTR or Eagle rear derailleur.
Pretty sure ratio tech has a shimano 12s mechanical conversion kit. It's not on their site but they'll sell it if you contact them directly. Someone here already did the conversion and said it works well.
The upcoming Sensah hydraulic brifters should work with SRAM Road 11/10s & MTB 10s RDs assuming the pull ratios are unchanged from Rim brake Empire Pro
L-TWOO RX & GRT 12s hydraulic brifters work with Shimano Road 11s & Tiagra 4700 10s RDs
of course, neither option would work as flawlessly as the upcoming 105 & GRX mechanical 12s
