Prime Primavera X-Light Pro handlebars
I’ll measure tomorrow but i don’t think there is any flareTofast wrote:Is there any flare or do they have the same CC at both hoods and drops?
Updates: No flare, drops are 36cm c-c.
Stiffness seems good, can’t feel difference going from 38cm deda zero100 (alloy) but i only tested on a trainer. Will post an update I can go outside and try some proper sprints and out of the saddle climbs
Update: wrapped with some fresh deda tape. Bars feel really good and stiff after some short test ride outside
Did you had a chance to look on the inside of the drops before wrapping them?
One i got have some loose carbon strands pocking on the inside together with more then few wrinkles. To be honest they look cheaper on the inside then most of other carbon parts i use.
Sent from my SM-G970F using Tapatalk
Mine seem okay, I „inspected” drops by putting my finger inside and i didnt feel any loose strandsIvanZg wrote:Did you had a chance to look on the inside of the drops before wrapping them?
- wheelbuilder
Outstanding cockpit position.e4rthm0ver wrote:And side view:
Sent from my SM-A526U1 using Tapatalk
Do you have any further information to share? How does it feel as you ride it? I have doubts about its strength since it is super light. I generally ride on hilly routes. Can it handle some heavy braking or steep climbs? It would be super cool if you answer my questions
@Bgoksay i was about to ask the same.
A guy on another forum told that handlebar flex a lot (from 5 to 8mm) and that sound a bit problematic. Is that true? How much a normal carbon handlebar flex?
Inviato dal mio Redmi Note 9 Pro utilizzando Tapatalk
Can you send a link of that forum?
Sorry, not a forum but somewhere on YouTube.bgoksay wrote:Can you send a link of that forum?
Let me check if I can find the link but i believe that you can easily find it with the brand tag.
I had the previous generation of the Prime X-Light bars last year (size 40 and 189 grams if memory serves me). They flexed like crazy, eventhough I'm weak and skinny at 176cm and sub 50kg. Sold them and got some Fizik R1 Chameleon bars, which were much, much stiffer.
