Saddle advice: fighting numbness
I have the SMP Full Carbon. It took me around 6 months to adjust and adapt. At the beginning i tilted the tip down, but then settled on a horizontal setup (leveling it based on the highest points at the front and back), just like a... saddle. It passed a short 3-day trip "test" so it's considered comfortable to me. Also, I thought I was sitting correctly at the trough but the fore-aft reference point should really be the middle of the straight slope. Coincidently the saddle is clamped at the middle of the rail.
I think OP should find a shop that provides saddle test / trial. I first sat on a Composite on a fitting jig.
- wheelsONfire
Back when i had a severe issue with my left knee, went to a center for issues releated to sport. They told me saddles were not really optimal if you don't sit at one spot, which they also doubted we did when cycling for hours. I can't really describe the conversation as english isn't my main language. But i guess the more we move (back and forth), the more potential issues arrise. None of the custom made saddles is made for "sliders". So i haven't gone down the route of a custom made saddle.
Bikes:
Open *UP* (2016.04.14)
Agree. I am not on board with this short saddle trend. Yes, some of them are comfortable - Specialized S-Works Phenom - for a short period but for those of use who are used to using different positions for different terrain, for many these short nose, saddles with a rear ramp are not really that comfortable over the long haul. My wife really wishes Selle Italia would bring back the long, flat Prolink saddles.wheelsONfire wrote: ↑Tue Jan 31, 2023 4:14 pmNone of the custom made saddles is made for "sliders". So i haven't gone down the route of a custom made saddle.
- Michael
I know I am repeating myself but let’s get a bit more anatomical. The OP can’t feel Big John. That strongly suggests interference, pressure on the pudendal nerve.
It is not uncommon for some cyclist to have a pudendal canal that is not deep enough, so the nerve doesn’t “clear” saddle pressure. By the same reasoning you can also understand how too much padding can press up into the canal and cause the same problem.
Often a flatter saddle with a central relief area can solve the problem. My brother had the identical issue as the OP, I gave him one of my SQ Lab saddles – problem solved.
Failing that a massive cutout as only found on the Infinity might do it.
You can buy a selle italia superflow Slr replica from AliExpress for £30. It's 110g and more hole than carbon.
It's a great place to star if you need to try something different.
I have one and it's comfy, but a touch wide on the nose for my liking. Totally useable and robust for road and gravel.
Depending on the cause of the issue, the Superflow can be a problem solver. But for some sufferers of cryo-penis, pressure on the sitbones equals pressure on the pudendal nerve. AFAIK, the Infinity saddle (E2 and E3 models) is the only saddle that has no sitbone contact which makes it unique in terms of providing relief for a range of saddle contact issues.Steve Curtis wrote: ↑Tue Jan 31, 2023 7:57 pmYou can buy a selle italia superflow Slr replica from AliExpress for £30. It's 110g and more hole than carbon.
This is true. However, it's a cheap way to rule out, or potentially confirm what does/ doesn't work. Even if it narrows down the search to the more extreme saddles you mentioned, it could be worth a shot.Mr.Gib wrote: ↑Tue Jan 31, 2023 8:03 pmDepending on the cause of the issue, the Superflow can be a problem solver. But for some sufferers of cryo-penis, pressure on the sitbones equals pressure on the pudendal nerve. AFAIK, the Infinity saddle is the only saddle that has no sitbone contact which is what makes it unique in terms of providing relief for a range of saddle contact issues.Steve Curtis wrote: ↑Tue Jan 31, 2023 7:57 pmYou can buy a selle italia superflow Slr replica from AliExpress for £30. It's 110g and more hole than carbon.
I'll be honest and say, whenever I've experienced this issue it was down to my set up, rather than the saddle.
It's a terrible affliction to endure when all you want to do is ride your bike. I hope you find a solution.
This.Mr.Gib wrote: ↑Tue Jan 31, 2023 7:38 pmI know I am repeating myself but let’s get a bit more anatomical. The OP can’t feel Big John. That strongly suggests interference, pressure on the pudendal nerve.
- wheelsONfire
Then again, if he like to move back and forth some saddles aren't good at all. Might be great for a fixed position rider, but if you're moving (alot) it's very different.
Bikes:
Are you sure it's saddle? I'm a big guy and I worked out it was the tightness of clothing. The cycling world xxl is L. Try going for a ride in normal loose shorts or track suit bottoms. Short nosed saddles helped too. The ebay ec90/spec knock off being a cheap way of finding out.
- wheelsONfire
Or something like (heavy) https://speedandcomfort.com/products/type-r
Bikes:
Not sure to which saddle you are referring, but SQ Lab has more position options than just about any saddle. Three main options with a couple of variations of each. Crazy how much you can move around on it. The Infinity OTOH has just one main position, but you can change it up with more or less pelvic tilt.wheelsONfire wrote: ↑Thu Feb 02, 2023 9:09 pmThen again, if he like to move back and forth some saddles aren't good at all. Might be great for a fixed position rider, but if you're moving (alot) it's very different.
I was out on my SQ Lab today after 5 days on the Infinity. The SQ Lab would be my choice for pudendal nerve entrapment syndrome. The Infinity could also work if the entrapment was more posterior as the sitbones are hanging in empty space. However the nose of the Infinity rises up and contacts the front of the perineum so could be an issue. Cool thing about the Infinity is that you ride for an hour and then realize you haven't got out of the saddle once. Just disappears under you.
OK, first of all, thanks for all the advice. Yes, it's a weird and unpleasant problem to solve.
I've tried tilting my saddle both up and down (the nose) but this causes me to have lower back problems. I've been riding my saddles spot-on level for as long as I can remember and maybe I've adjusted myself to it. Anyway, never had lower back problems and don't want to go down that route. Tilting no option.
Second, tried sliding my saddle back and forth and mainly sliding my saddle back (more saddle to bar distance) seems to have an impact. The time it takes to go numb seems to be substantially longer. Right now, I am in the process of trying this solution with both my ISM saddle and my Pro Stealth.
Next step might be trying a new saddle. @Steve Curtis: you have any link for the Superflow Aliexpress version? Thanks
What I am also doing is lifting my butt in the air more often while riding, as a temporary quick fix. Do I feel a direct improvement "down there"? Sadly not, I fear that 20 years of numbness is not solved in a few weeks...
He ride a bike instead of a car I wanna be his friend
Golden Earring - Going to the run
I can't link to any specific ads as it depends where you are in the world. You find them but searching Selle Slr carbon.
