Cannondale SuperSix Evo4
The general all-things Road forum!
LanceLegstrong
by LanceLegstrong
ediryppah wrote:
Tue Oct 29, 2024 9:06 am
johnpuga1982 wrote:
Mon Oct 28, 2024 7:26 pm
Cycling Weekly comparisons of two models.
Always the same conclusion on these types of comparisons. Would be a lot more fun if someone just plain roasted the "cheap" variant saying that 105 is shit, a stupid alloy bar is shit and then laugh at poor people.
And that's coming from me that's currently getting a Evo 3 being built up at my LBS.
What I would love to see, though I doubt would ever happen, is get some real testing of the difference tiers of frames. Like take a Lab71, Hi-Mod, and standard frame, strip them down to bare carbon so you can't tell which is which, then build it up with the same exact components. Then have a bunch of people ride them and rate them. Do the same with S-Works and Pro frames. A blind taste test as it were.
Cannondale SuperSix Evo gen 4
Specialized Crux
Specialized Epic 8
GrassQ
by GrassQ
My quess is : in that context nobody (or almost nobody) could tell the difference, when the placebo effect has taken away.
tyoac
by tyoac
eddymurks wrote:
Sat Nov 02, 2024 12:40 am
Is anyone running the F1X bars on their supersix evo? If so, any photos or experience would be appreciated! I'm after an integrated bar/stem and am losing the will to live waiting for EXS to ever have stock of 360 x 120
I read somewhere that the EXS gets quite noodly on the SSE cause of the shims you need to use. Only reading into integrated cockpits slightly, I'm still on the regular stem + Pro Vibe Aero SL and not sure where I'm going with my fit before I drop some cash on an integrated cockpit which locks me in then of course.
Tavelo AVRO Avro might be another option you could look into, similar looks to the EXS, a touch heavier and less expensive.
sageorguk
by sageorguk
Anyone got the Avian Falcon? Supposedly stiffer than the Canary.
LanceLegstrong
by LanceLegstrong
GrassQ wrote:
Sat Nov 02, 2024 9:14 am
I believe the same. That's exactly why the brands wouldn't want it to happen. So no major cycling publication would do it. And I doubt any normal person would care enough to drop that much money on multiple frames and builds.
Specialized Crux
Specialized Epic 8
eddymurks
by eddymurks
tyoac wrote:
Sat Nov 02, 2024 10:21 am
Nice, thanks for the tip - I'd not heard of that bar before.
ryanshady
by ryanshady
No noodly at all, quite stiff and agressive for me. It is a great handlebar if you want to get low and go fast. For me i want to be more conformtable on longer ride so I changed to momo system bar r one
Philbar72
by Philbar72
sageorguk wrote:
Sat Nov 02, 2024 11:37 am
that was the one i was looking at, they state (according to a message on instagram) that its fully compatible with our Supersixes.... which is nice.
goixiz
by goixiz
Switching stem-bar from stock SSE 2024 (conceal stem) to one piece bar+stem what shims is needed for the delta steerer
SSE C1 stem parts.jpg (22.62 KiB) Viewed 1075 times
- Eat More Rice !
ediryppah
by ediryppah
I got my SSE3 just days ago and in an effort to not cut the steerer right away I figured I'll at least reduce the massive amount of spacers and try it out a bit.
But, I'm not really sure I'm doing this right. Slightly (or very) confused.
I removed 20mm of spacers below the stem, and then added 20mm of spacers above. But with the systembar top cap (or whatever it's called, the round top cap) I can't get any thread engagement. Looks like this with 20mm on top:
This works with the conceal top cap though, but looks really wonky.
With 15mm of spacers on top I don't get proper compression, this is the look with 15mm spacers on top:
I ended up with (I think) 19mm but had to use some wider carbon spacers. Seems to work, but haven't ridden it.
Am I OK riding this?
Honestly if I replicate the fit of my current bike I can slam it all the way but I want to test out a higher/shorter position a bit to see if it enables me riding in the aero tuck more.
Also, is the only manual available the supplement on the website? I feel like it's lacking but maybe that's just the nature of a bike manual (I haven't looked in one ever before because I've only ridden bikes without proprietary parts/solutions).
harblhat
by harblhat
You're probably ok short term to figure out your fit, but not long term. The compression plug supports the steerer against the stem clamping force, and your current setup supports the wrong part of the steerer.
I also don't see the wedges - I assume you're using them, they're critical
ediryppah
by ediryppah
harblhat wrote:
Tue Nov 05, 2024 2:47 pm
The black wedges are there, just further down (which looking at the manual they should be).
johnpuga1982
by johnpuga1982
ediryppah wrote:
Tue Nov 05, 2024 2:41 pm
I removed 20mm of spacers below the stem, and then added 20mm of spacers above. But with the systembar top cap (or whatever it's called, the round top cap) I can't get any thread engagement...
With 15mm of spacers on top I don't get proper compression, this is the look with 15mm spacers on top...
I ended up with (I think) 19mm but had to use some wider carbon spacers. Seems to work, but haven't ridden it...
I had a similiar experience when I installed the Momo bar. In order to get proper compression I needed the the delta steerer tube to be flush with the Momo bar stem. -1mm was too short and the round top cap threads would not engage the delta compression plug. +1mm and there was not enough compression. I would say use enough spacers to get the top of the delta steerer tube and the spacers flush, then use the round top cap. From what I can see, 17/18 mm of spacers may be the correct size for your use case. If 19mm works and you feel no play, then your assessment is correct.
Also, in my case, I had to sand down one of the spacers to get back the -1mm I cut from my steerer tube. I have 20mm of spacers installed on my bike. I had planned to slam my stem, but I wanted to leave some error room when I cut the delta steerer tube. I've been too lazy to slam the stem and the bike feels good with 20mm of spacers, so I just let it be.
I think it's safe to ride your bike like this for a short while, but I agree with what harblhat said about the clamping forces.
Cut Steerer Tube
Cut Steerer Tube
Tube Data
Tube Data
BobbyB on page 164
BobbyB on page 164
goixiz
by goixiz
Question: 2x half round/moon shim for delta steerer.
Are there 2 kinds - one for carbon stem/onepiece carbon stem-bar and another for alloy stems ??
TIA
- Eat More Rice !
ediryppah
by ediryppah
goixiz wrote:
Wed Nov 06, 2024 4:43 am
TIA
Delta Filler pieces come in black and pink/purple (or rather magenta).
The black ones goes on the conceal stem assembly, and the manual states the magenta ones to be used on the SystemBar-assembly.
I haven't had a look at the parts and figured out what the difference is though, but I'm sure someone else has.
