Cannondale SuperSix Evo4
The general all-things Road forum!
goixiz
by goixiz
johnpuga1982 wrote:
Sat Dec 07, 2024 11:29 pm
goixiz wrote:
Sat Dec 07, 2024 10:55 pm
so how it looks is more important than how it fits ?
use your current bike stack and reach and that will get you close to what you should get.
So you'd rather talk trash than understand why he's asking the question? Let the man ask the question.
good luck
- Eat More Rice !
mr.wulf
by mr.wulf
eddymurks wrote:
Sat Dec 07, 2024 3:46 pm
Are there any folks 6'2 running either a 56 or 58 that can share side on photos? I'm trying to choose between the two sizes, thanks.
I am 6´1 (186cm) with long legs (90cm). This is size 56 with 81cm saddle height - if this helps you.
eddymurks
by eddymurks
mr.wulf wrote:
Tue Dec 10, 2024 1:48 pm
Thanks, that's handy. What length stem is that?
mr.wulf
by mr.wulf
eddymurks wrote:
Tue Dec 10, 2024 4:14 pm
100mm - standard length on Size 56 fits me well.
ridenfish39
by ridenfish39
I'm about 6'2" with long legs and arms, saddle height is 32 3/8" from center of bb to the top of the saddle. Size 58 cm. Momo stem length is 120, I wish they made a 130 but it still fits good.
eddymurks
by eddymurks
ridenfish39 wrote:
Wed Dec 11, 2024 12:53 pm
Thanks for sharing! Looks great with the momo bars, shame they're so hard to get in europe!
friedrichk
by friedrichk
While trying to remove the top cap of my new Supersix Evo, instead of the expander fixing bolt on top, the bottom counterpart of it became loose and fell into the fork. As it became stuck there, it took me 30 minutes until it finally managed to get it unstuck and out of the frame. Does anybody have an idea how I can prevent this from happening? Until now I didn't even manage to loosen the expander fixing bolt on top as only the bottom part is turning
johnpuga1982
by johnpuga1982
friedrichk wrote:
Sun Dec 15, 2024 12:52 am
Whoever assembled your bike probably used locktite. To be fair to them, it does say to use it in the Owner's Supplement. However, I don't recommend it and don't do it. In your picture it looks like the the compression nut is stuck to the expander fixing bolt. Is this true?
friedrichk
by friedrichk
johnpuga1982 wrote:
Sun Dec 15, 2024 1:47 am
Yes, correct. That was also my guess on why it is stuck. So I should, as soon as I manage to remove the nut, remove the loctite at the top and probably apply some at the bottom?
I guess that's what I get for ordering from a big multibrand online shop instead of buying at my local bikeshop which has experience with these bikes :lol:
johnpuga1982
by johnpuga1982
friedrichk wrote:
Sun Dec 15, 2024 2:02 am
DO NOT APPLY LOCKTITE TO THE BOTTOM!!! That little piece that fell off is what causes the expander plug to expand inside the delter steerer tube. I've attached a video of the expander in action. It was a little hard to film and screw the expander plug with one hand. However, you should still be able to see how it works.
https://youtube.com/shorts/ltq6ZFWkhlA? ... i5Dt1sOWSn
londonbairn
by londonbairn
What is the difference between the SSE 2023 and 2024? The 2023 (e.g. in Chalk white) is called a 3 by Cannondale, and the 2024 is called a 4. From what I can see they are 100% identical, and only difference is the colours? How good is the HiMod then vs these frames?
mr.wulf
by mr.wulf
londonbairn wrote:
Sun Dec 15, 2024 4:00 pm
SSE Gen 4 is available as a 3 Model (105 Di2) or as a 4 Model (105 Mechanical).
AndyTheSnail
by AndyTheSnail
Do the Hi-mod framesets ever get discounted in the US?
I see some references to sales earlier in the thread but it's unclear about location. I would like to build from parts but 4.5kusd is a little hard to swallow. I'm not in any clear rush so could wait for a sale if they do happen
EddyTwerckx
by EddyTwerckx
AndyTheSnail wrote:
Wed Dec 18, 2024 5:24 pm
A couple shops in the northeast US had discounts on Hi-Mod and Lab71 framesets a while back (Conte’s and Strictly Bicycles). I think Conte’s ships. Strictly would be pick up only. I think Mikes Bikes does sales every now and then. It’s a lot of luck to find one on sale in your size.
ToileySiphon
by ToileySiphon
Besides the post slippage (which seems to have been resolved with a new wedge), does this bike has any major know issues?
Hiw is the delta steerer holding up after a while? Any issues with it? And does it comes with a glued in compression plug?
Envoyé de mon Pixel 7 Pro en utilisant Tapatalk
