Campy UT bb cups ITA
Think they went out of stock during the pandemic (factory shutdown). Then after a dry spell i found some at the normal price. Suggest continuing to keep looking as there is no reason they would be discontinued.
What's the difference? Curious if there any apart from the label?
Giant Propel Advanced SL Red Etap 11s Easton EC90 wheels CeramicSpeed BB Zipp SL70 bars 6.5kg
Vitus ZX1 CRS Campy Chorus 12s Bora WTO 45 disk brake wheels Zipp SL70 bars 7.5kg
SL8 build with Craft CS5060 Wheels in progress
That's annoying. Arguably you need the better seal for the SR bearings.Bobbyc123 wrote: ↑Fri Dec 09, 2022 1:49 pmMain thing for me is the colour, black vs grey but also Super Record cups do not have the inner seal, Record Cups have a white seal for the different bearings.
Campy promoted that the SR ceramic doesnt need as much sealing......plus less seals gives an addtional fractional reduction of drag.
Those seals in the Record cups - they are easily removed.
- MrCurrieinahurry
- Moderator
Might be worth contacting a few high end bike shops see if any laying about in spares drawers etc. Places like sigma/condor/chicken etc.
Are u uk?
Basso Diamante eps 12
Are u uk?
I was able to find a couple pairs here (US) about a year ago, nothing since.MrCurrieinahurry wrote: ↑Sat Dec 10, 2022 10:11 amMight be worth contacting a few high end bike shops see if any laying about in spares drawers etc. Places like sigma/condor/chicken etc.
Are u uk?
I genuinely thought the crank bearings slide into the frame and so go 'behind' the Campy cup seals (and so the cup seals are not directly in contact with the balls as most normal bearing seals) and so would not impact the bearing efficiency as contact seals do.
So if I switched out my current Chorus 12s cranks for new SR 12s cranks I would also have to remove the cup seals, or get new SR bb30 cups to gain the full benefit of the CULT ceramic bearings?!?
Yep. Uk based.MrCurrieinahurry wrote: ↑Sat Dec 10, 2022 10:11 amMight be worth contacting a few high end bike shops see if any laying about in spares drawers etc. Places like sigma/condor/chicken etc.
Are u uk?
I've got a chicken account and they've got no stock. I was in condor the other day and they also mentioned they were trying to scoop up what they could find but have been out for a while.
From Graeme @ velotech on record vs SR cups:
SR were soft anodised, black. RE is a harder and more durable (IME) anodisation in olive green.
I was told a few years ago by a colleague / tech at the factory that SR bearings being Cronitect Inox, were better at resisting both simple and complex corrosion and were fine coupled with soft anodisation, where RE and CH bearings, using a non-Inox bearing surface were more prone to corrosion and so benefitted from a harder anodised cup with lower corrosion propensity.
There may have been loss in translation but that seems reasonable as an explanation, though I'm no expert in metallurgy ... whereas my colleague was / is.
