'22 Cervelo R5 versus '22 BMC SLR01
I have both. First BMC are more stiffer thank R5, for the ride is more better R5, for climb is better R5, the BMC are super stiff.
the R5 can use FSA vision metron handlebar integrated it is fine, the BMC use their own handlebar.
I will choose R5>SLR01 because:
the R5 recently has all the new design perfomance in this year 21-22. I don't like SLR01 for climbing, is to stiff
Some pretty major differences between those frames in my (54cm) size. The R5 has a 12mm shorter wheelbase and more BB drop. The R5 has nearly 6mm less trail. The R5 is therefore going to be significantly more "agile" while the Teammachine might feel more "stable." If you enjoy twisty descents with quick chicanes, choose the R5. If you like long rides through rolling countrysides, maybe choose the Teammachine.
Looks like I may be going R5.
Bike shop is giving me a deal on the build and I can spec it with either Roval Alpinist CLX or Roval Rapide CL II. I like the idea of the super light Alpinist but think I would miss the aero advantages of the Rapides on fast group rides. The rest of the build will be Ult 12sp DI2. Thoughts?
R5 with Rapides is a super solid setup all around. I'd go with Vision bars too if it was me. Would be a JV setup but with faster wheels
