Going from Allez Sprint to S-Works SL5?
So I have a 2016 Allez Sprint (amongst others) and have reached the point where I've maxed it out, Dura Ace Di2 full groupset, a choice of Roval CLX32 & 64 wheels, S-Works stem and Aerofly bars etc and think perhaps the frame set is perhaps now the worst part of the build
So I'm buying an S-Works SL5 (same year 2016) thinking this'll be a nicer build now I've had the Allez Sprint a couple of years, take everything off the Allez and fit it all to the SL5 and wondered what to look out for? Will I notice a big difference? Weight, handling etc.
I've really enjoyed the Allez Sprint but think it's time to move it on
Less gocart and more comfort. I went from an SL5 to an Allez Sprint
/jonas l
http://instagram.com/jonaslundb
I had Allez Sprint and went to SL5 Tarmac Disc. Same small clearance for tires: couldn't fit 28c. No big improvements on comfort. I wish I kept mine Edition X1 bike instead and saved the money.
His: Orbea Orca OMX
What do you want to know about the SL5, I own 2 of em.. one in the Sagan camo colors, and one in the Nibali Shark scheme.. both have Campy EPS... the Shark is the newest edition to the fleet, I have an SL6 and a Venge, and I actually find myself on the SL5 the most...
Hi ParisCarbon, are yours rim brake models, what sort of weight have you got them at? All my other bikes are disc brake Specialized models, 3 x SL7s inc S-Works and 2 x Diverge models, I want to keep a rim model in my stable for travelling, so much easier packing cabled breaks in a case than hydraulic brake pipes with very little movement to detach bars etc IMO.
Is the SL5 stiff in comparison to newer models? Was looking to get an SL6 S-Works but still a bit pricey to justify to the Mrs
Travelling with disk brakes should be just as easy as with rim brakes, as long as you have sufficient slack available in the hoses to allow removing the bar/stem to pack the bike in a bike bag.
IMO more of an issue with internal cable routing (e.g. SL7), but should not present any problems for sensibly built frames with external routing (e.g. SL6 and many others).
When I travel with a bike it's usually to ride in the mountains, so I prefer a travel bike with disk brakes.
Giant Propel Advanced SL Red Etap 11s Easton EC90 wheels CeramicSpeed BB Zipp SL70 bars 6.5kg
Vitus ZX1 CRS Campy Chorus 12s Bora WTO 45 disk brake wheels Zipp SL70 bars 7.5kg
SL8 build with Craft CS5060 Wheels in progress
Yes both are rim brake.. one has EPS 11, the other has EPS 12... both are 58s...Ill get a weight on em tonite and post that with the specs... vs the SL6.. in all honesty.. I cant tell... going to my venge off either an SL5 or 6 is where I feel the difference...Nick38 wrote: ↑Sat Dec 03, 2022 9:45 pmHi ParisCarbon, are yours rim brake models, what sort of weight have you got them at? All my other bikes are disc brake Specialized models, 3 x SL7s inc S-Works and 2 x Diverge models, I want to keep a rim model in my stable for travelling, so much easier packing cabled breaks in a case than hydraulic brake pipes with very little movement to detach bars etc IMO.
Cheers ParisCarbon appreciate itParisCarbon wrote: ↑Mon Dec 05, 2022 5:10 pmYes both are rim brake.. one has EPS 11, the other has EPS 12... both are 58s...Ill get a weight on em tonite and post that with the specs... vs the SL6.. in all honesty.. I cant tell... going to my venge off either an SL5 or 6 is where I feel the difference...Nick38 wrote: ↑Sat Dec 03, 2022 9:45 pmHi ParisCarbon, are yours rim brake models, what sort of weight have you got them at? All my other bikes are disc brake Specialized models, 3 x SL7s inc S-Works and 2 x Diverge models, I want to keep a rim model in my stable for travelling, so much easier packing cabled breaks in a case than hydraulic brake pipes with very little movement to detach bars etc IMO.
