Campagnolo Bora Ultra 50 needs help
mnmasotto
by mnmasotto
I ride Colnago v2r with Campagnolo 12 speed mechanical. I have Bora Ultra 50 clinchers. When riding on flat roads with a fairly high caidence when I stop pedaling the cassette tries to continue spinning with the hub putting slack on my top chain which slaps the adjacent arm. It appears the cassette and freehub do not disingauge and spin freely. Any help with this issue would be appreciated.
maxim809
Administrator
by maxim809
This, or different?
viewtopic.php?f=3&t=165212
MrCurrieinahurry
by MrCurrieinahurry
Hope this helps
Answer is shouldn't make any odds, 10, 11, 12s all should spin OK, it's likely the cassette body or maybe the spring just grazing the inside of the drive ring.
Strip, clean, have a look.
If it is, it's obvious the guy will see marks on the cassette body.
New cassette body in that case. If the wheels are new / still in warranty,, they need to go to a SC for proper evaluation.
If the guy has flipped the cassette body at any time the gasket between the cassette body and the hub might be snagging. Worth a check it's properly positioned.
Basso Diamante eps 12
mnmasotto
by mnmasotto
Yes, same problem. I have four other bikes, all running 11 and 12 speed Campagnolo groupsets. All my bikes have the same Bora Ultra 50 wheels. None of the other bikes have this issue. I will take rear wheel apart again and try to find a solution
micky
by micky
Campagnolo 12s cassette way too heavy and it hold the "momentum" and keep going forward.
I have this exact situation with my own bike and it doesnt happen when I use the Edco steel cassette (roughly half weight).
ParisCarbon
by ParisCarbon
My 12s stuff does it to on all my Campy wheels... WTOs, WTO Ultra, and Bora Ultra 50s.... they only do it with the 12s, 11s is fine.... I think like Micky said..its the momentum of the cassette carrying forward that slaps the chain on the chain stay...
MrCurrieinahurry
by MrCurrieinahurry
I've never had the issue with shamal ultras and 12s . 11/29 sr cassette
