38 cm aero handlebar?
I don't think there's tons of options that are 'not so wavy', unless you were open to an integrated barstem. Maybe the Deda Vinci, 40cm outside to outside, would fit the bill.
Prime Primavera Aero?
229.2g for the 38cm
https://www.wiggle.co.uk/prime-primaver ... -handlebar
36cm is in stock, with 38cm in 2-4 weeks
229.2g for the 38cm
Cervelo S3 Disc - 6.78Kg/14.15Ib
Scott CR1 - 5.69Kg/12.56Ib
Scott Addict RC - TBC 7.4Kg/16.30Ib
OnOne - Free Ranger - 8.68Kg/19.1Ib
Vision Metron Aero in size 40cm is 38cm wide at the hoods and 40cm at the drops.
Scott Addict RC / SRAM Force eTap AXS 2x12/ Campagnolo Bora WTO 60 Disc / Continental GP 5000 TL 25mm
Trek Emonda SLR / Shimano Ultegra Di2 2x11 / Reynolds ATR 40 / Schwalbe Pro One TLE 28mm
Deda Superzero RS (40cm is 38 c-c) is really nice. Like the Rapide but a bit more comfortable to hold on the tops.
Zipp SL70 Aero is also available in 38cm.
/jonas l
http://instagram.com/jonaslundb
So i have orderd the Vision Metron Aero. Today it arrive. But the front part of the handlebar, facing into the wind, is almost flat and more that 2 cm high. How is this supposed to be aero? Should it not be more rounded like the bottom of a waterdrop?
I recently purchased these. Yet to try them. Suitable for integrated cabling as they got the hole at the back.
https://www.3t.bike/en/products/dropbar ... x-714.html
ever mm counts. more narrow you gain 4-5 watts.
https://www.aero-coach.co.uk/store/Aero ... p509540543
Current Rides:
2019 S-Works Tarmac SL6 Bora Di2 9150
ex 2018 Trek Madone SLR Disc
ex 2016 Giant TCRAdvanced Sl
ex 2012 Trek Madone7
- zappafile123
Only get the Primavera if you run eTap or Di2. The drillings are really badly designed and you cant fit both the shift and brake housing through the bars. Aside from this fundamental design flaw which 100% warrants not buying them if you run mech groupsets, they are fine.stevec1975 wrote: ↑Tue Nov 22, 2022 6:51 pmPrime Primavera Aero?
229.2g for the 38cm
Sarto Seta|StorckF.3|Enigma Elite HSS|SworksSL6|ColnagoC60/V3Rs|DeRosa Protos|Bianchi XR4/2|BMC SLR01 16|Cdale EvoHM|Focus IzMax|RidleyHelium SL/SLX|BH Ultralight|BassoDiamante|Scapin DyseysS8|Time RXRS/ZXRS|TCR SL|RidleyNoah|Look585|CerveloSLC
I wonder if the Primavera design has changed. My other half runs a pair of 38's with mechanical Ultegra and absolutely no problem with shift and brake cable routing. They are a few years old tho.zappafile123 wrote: ↑Mon Nov 28, 2022 10:07 amOnly get the Primavera if you run eTap or Di2. The drillings are really badly designed and you cant fit both the shift and brake housing through the bars. Aside from this fundamental design flaw which 100% warrants not buying them if you run mech groupsets, they are fine.stevec1975 wrote: ↑Tue Nov 22, 2022 6:51 pmPrime Primavera Aero?
229.2g for the 38cm
Giant Propel Advanced SL Red Etap 11s Easton EC90 wheels CeramicSpeed BB 6.5kg
Vitus ZX1 CRS Campy Chorus 12s Bora WTO 45 disk brake wheels Yoeleo H10 bars 7.5kg
An updated version was released in 2021.Nickldn wrote: ↑Mon Nov 28, 2022 4:43 pmI wonder if the Primavera design has changed. My other half runs a pair of 38's with mechanical Ultegra and absolutely no problem with shift and brake cable routing. They are a few years old tho.zappafile123 wrote: ↑Mon Nov 28, 2022 10:07 amOnly get the Primavera if you run eTap or Di2. The drillings are really badly designed and you cant fit both the shift and brake housing through the bars. Aside from this fundamental design flaw which 100% warrants not buying them if you run mech groupsets, they are fine.stevec1975 wrote: ↑Tue Nov 22, 2022 6:51 pmPrime Primavera Aero?
229.2g for the 38cm
