Shimano 12-speed cassette with SRAM AXS?
DaveS
by DaveS
Sram does not allow the small ring and smallest sprocket to be used. The flashing red light is normal. I would expect poor shifting if you really have a mismatched 52/34 chain ring setup. It works perfectly with a Chorus 48/32 and should work with a 50/34 or 52/36, if you can get the FD up high enough.
Micro adjusting is like tightening or loosening the RD shift cable on mechanical system, Whatever works with the big ring should work for the small. Be sure to back out the limit screws before micro adjusting and only set them in to touch when micro adjusting is complete.
I only used an AXS chain when I ran a Campy 12 cassette, but either should work. The Campy chain would probably work better with an 11 speed crank.
defy1
by defy1
defy1 wrote:
Wed May 10, 2023 11:47 am
Thinking of going 12 sp budget style with the Ratio kit and my current sram red 22 11sp.
Will this work ok?
50/36sp 11sp FSA chainrings
12sp Shimano Ultegra 8100 cassette
Chain : KMC 12sp
OR YBN 12sp
OR 8100 12sp
Seems from reading this thread, the chain can be a big factor.
Happy to report I have completed my conversion and it all works great! Ended up with a shimano 8100 chain and the Shimano specific Ratio kit. Did my first 40mile ride with the setup and didn't have any major problems, except some minor tweaking with the barrel adjuster. Glad to be able to get a 12 sp setup, with a just a $180 cost.
If anyone has any questions let me know.
TLN
by TLN
Have two bikes, one is Sram AXS (Force/Red), another is full Ultegra 12sp. Also have a trainer: wahoo kickr, with both kinds of drivers but no 12sp cassette yet.
What is the most optimal way to pair it all together? I can easily have a wheelset for each bike, but what to do with the trainer?
His: Orbea Orca OMX
ultimobici
by ultimobici
TLN wrote:Have two bikes, one is Sram AXS (Force/Red), another is full Ultegra 12sp. Also have a trainer: wahoo kickr, with both kinds of drivers but no 12sp cassette yet.
For the trainer to work properly with both bikes you’ll need two cassettes. Although the spacing is close enough, the rollers on AXS are bigger.
TLN
by TLN
ultimobici wrote:
Tue Jun 06, 2023 9:47 am
What parts I'll need to swap on Ultegra bike to keep everything close to Sram eco system?
Cassette and chair, or crankset as well?
His: Orbea Orca OMX
ultimobici
by ultimobici
You’ll need to change the same items on whichever bike you change. Cassette, chain & chainrings (or chainset). It’ll be cheaper to swap the Sram bike to Shimano I would think. That way you could use a Shimano 7100 cassette on the trainer.
TLN
by TLN
That's what I thought.
Not sure how it's cheaper to move Sram bike to Shimano. When I bought mine,Sram Force groupset was cheaper than Ultegra. I already own spare Force/Red parts (cranks, PM, cassette), so it's matter of buying rival/new Force shifters and dereileurs for me.
His: Orbea Orca OMX
ultimobici
by ultimobici
I’m presuming you’re running 2x on both bikes?
While Sram seems to play ok on Shimano, I’m not sure anyone has tried it the other way round. If you’ve got the parts spare you might as well as try it.
You need only swap out the drive train - cassette, chain, cranks & bb.
TLN
by TLN
ultimobici wrote:
Tue Jun 06, 2023 8:41 pm
I was sold on Sram, but got a good deal on bike with UDi2. Not we have two 2x bikes in household on opposite groupsets.
I am considering building another frankenstein commuter bike: Canyon Grizl AL Suspension with dropper post, so both of us can ride it. Might keep this one on a trainer.
I think it's easier to try it outmyself and see how two groups play out. I got more (better?) Sram parts, so might convert new bike to Sram.
His: Orbea Orca OMX
joshmart10
by joshmart10
bobones wrote:
Mon Dec 05, 2022 11:08 am
For the doubting Thomas' among you ...
Ultegra with Rival AXS (Ultegra chain) - good shifting
105 with Force AXS (Force chain) - 1 mm spacer (micro adjust at position 16) - good shifting if a little noiser than with Shimano chain above
105 with Force AXS - no spacer. Chain jumping on big ring with micro adjust at anything higher than 7 but still noise lower down at position 9 - no acceptable compromise
Hi!
I am building a SEKA Exceed with 52-36 Magene QED chainring and 11-32 ZTTO cassette. I am planning on putting SRAM Rival AXS as my shift kit. Will it be okay if I use a SRAM Rival D1 Wide FD for my set up?
Thanks!
bobones
by bobones
joshmart10 wrote:
Mon Jun 12, 2023 6:33 pm
Hi!
Thanks!
Hi. I don't think you want the Wide Rival FD, just the standard one. The wide one is for use with wide format cranks that have a longer spindle to provide clearance for large tyres on gravel bikes etc. I don't know much about the Magene, but I think it's just a standard (non-wide) crank, although I could easily be wrong.
One potential problem you may have is getting the FD high enough on the braze on tab to clear your 52 ring. It might be OK, but if not, you'll need an adaptor to allow the FD to go higher. I had a Scott where the braze on adapter was fine and my current bikes running 52/36 chainsets have band-on FD mounts so they can easily be moved up.
joshmart10
by joshmart10
bobones wrote:
Mon Jun 12, 2023 7:52 pm
Hi!
Thanks!
Thanks for your insight! Much appreciated
joshmart10
by joshmart10
Hi!
Thanks!
I have one more question, will the SRAM flat top chain work nicely on a ZTTO Cassette?
bobones
by bobones
joshmart10 wrote:
Mon Jun 12, 2023 8:31 pm
I don't know as I have never tried a ZTTO cassette, but my experience is that the flattop chain seems to work ok on non AXS 12 speed cassettes like Shimano and Sunshine (AliE). However, if you're not running AXS cranks or cassettes then a chain with standard sized rollers such as KMC X12 or Shimano may wear your drivetrain components less than an AXS chain with its bigger rollers.
joshmart10
by joshmart10
bobones wrote:
Mon Jun 12, 2023 9:11 pm
Got it! Thanks man! 🍻
