I agree. I am going to return the frame...now the only problem is finding another gravel frameset below 1000€ including a steel fork and with decent geometry.ultimobici wrote: ↑Mon Oct 17, 2022 11:36 amSounds like you are a little too understanding.matteof93 wrote:That is what I want to do.TobinHatesYou wrote: ↑Mon Oct 17, 2022 10:02 am0.1mm is borderline acceptable.
0.2-0.3mm is not.
I’d demand a return and my money back after that conversation.
Option 1: he replaces the frame with a new one that is properly made.
Option 2: return and refund.
His responses scream incompetence.
Seat tube out of spec: customer vs bike designer
- ultimobici
- in the industry
- Contact:
Where are you based?matteof93 wrote:I agree. I am going to return the frame...now the only problem is finding another gravel frameset below 1000€ including a steel fork and with decent geometry.ultimobici wrote: ↑Mon Oct 17, 2022 11:36 amSounds like you are a little too understanding.matteof93 wrote:That is what I want to do.TobinHatesYou wrote: ↑Mon Oct 17, 2022 10:02 am0.1mm is borderline acceptable.
0.2-0.3mm is not.
Northern Italy...the goal is to find a steel frame&fork that can be used with 700x45c tires minimum.
- ultimobici
- in the industry
- Contact:
For €1000 you’re going to have a hard time. Having worked for a mid to high end brand, I can tell you that for that sort of money you’re looking at secondhand or perhaps this Bombtrack?matteof93 wrote:Northern Italy...the goal is to find a steel frame&fork that can be used with 700x45c tires minimum.
https://paloaltobikes.it/prodotto/bombt ... -frameset/
Totally agree. Ask for a refund immediately - if there's any friction whatsoever then raise a credit card chargeback.ultimobici wrote: ↑Mon Oct 17, 2022 11:32 amFor a frame to have a seat tube so far out of spec is unacceptable. Strip the bike down, box it back up and ship it back for a full refund. While you’re at it, raise a chargeback with your credit card company.
Saying the frame is fine for 10nm is one thing, but what about the seatposts?
Asserting that the seatpost is freefloating below the clamp 'for flexion' sounds absurd. What he's actually talking about is the seatpost rocking in the frame, right? Which is totally different and surely not desireably or reliable.
This one is interesting https://www.veloheld.de/veloheld-iconx-rahmen/ultimobici wrote: ↑Mon Oct 17, 2022 1:38 pmFor €1000 you’re going to have a hard time. Having worked for a mid to high end brand, I can tell you that for that sort of money you’re looking at secondhand or perhaps this Bombtrack?
- ultimobici
- in the industry
- Contact:
Light, strong, cheap. Pick two.matteof93 wrote:This one is interesting https://www.veloheld.de/veloheld-iconx-rahmen/ultimobici wrote: ↑Mon Oct 17, 2022 1:38 pmFor €1000 you’re going to have a hard time. Having worked for a mid to high end brand, I can tell you that for that sort of money you’re looking at secondhand or perhaps this Bombtrack?
If I'm going for steel, it means I don't care about weight.
- ultimobici
- in the industry
- Contact:
The reference to weight isn’t to do with steel v carbon or aluminium.matteof93 wrote:If I'm going for steel, it means I don't care about weight.
A budget steel frame will either be quality tubing built poorly or nondescript tubing built to a better standard. Either way they may not be that nice to ride. Why the need for a steel fork too, I wonder?
With the British pound taking a pounding, this should easily come under 1000 Euros:matteof93 wrote: ↑Mon Oct 17, 2022 12:40 pmI agree. I am going to return the frame...now the only problem is finding another gravel frameset below 1000€ including a steel fork and with decent geometry.ultimobici wrote: ↑Mon Oct 17, 2022 11:36 amSounds like you are a little too understanding.matteof93 wrote:That is what I want to do.TobinHatesYou wrote: ↑Mon Oct 17, 2022 10:02 am0.1mm is borderline acceptable.
0.2-0.3mm is not.
https://www.fearlessbikes.com/warlock/
Not really, 1€ = 0.86£CampagYOLO wrote: ↑Mon Oct 17, 2022 4:27 pmWith the British pound taking a pounding, this should easily come under 1000 Euros:
As others indicated, the seat post should be secure for at least the minimum insertion depth. If it is not secure, regardless of the amount of torque applied to the clamp bolt, the seat post will slip down, but more importantly, internally the post will act as a lever that will continually move inside, elongating the inner bore and eventually either the seat tube tube will fatigue/crack or the welds of the attach points for the top tube and seat stays will fail!
- Michael
I agree, that is what I meant...you explained it perfectlyms6073 wrote: ↑Mon Oct 17, 2022 9:24 pmAs others indicated, the seat post should be secure for at least the minimum insertion depth. If it is not secure, regardless of the amount of torque applied to the clamp bolt, the seat post will slip down, but more importantly, internally the post will act as a lever that will continually move inside, elongating the inner bore and eventually either the seat tube tube will fatigue/crack or the welds of the attach points for the top tube and seat stays will fail!
BTW, I could buy this Fuji Jari frameset for 500€ (500$ basically) in a near by shop...used for 800 km, so it is basically new
- ultimobici
- in the industry
- Contact:
I thought you were after steel with a steel fork?matteof93 wrote:I agree, that is what I meant...you explained it perfectlyms6073 wrote: ↑Mon Oct 17, 2022 9:24 pmAs others indicated, the seat post should be secure for at least the minimum insertion depth. If it is not secure, regardless of the amount of torque applied to the clamp bolt, the seat post will slip down, but more importantly, internally the post will act as a lever that will continually move inside, elongating the inner bore and eventually either the seat tube tube will fatigue/crack or the welds of the attach points for the top tube and seat stays will fail!
