Hey all,
I have a new Canyon Inflite which has Ultegra DI2 and GRX rear. I want to replace the 46/36T front chain ring with a 52/36T. Apart from moving the front mech up is there anything else I need to do? If I add a new longer chain will the rear mech need adjusting?
I have come from Sram AXS and have no idea how to set up shimano.
Cheers
Ultegra DI2 Chain length
Thanks mate. IS there a measurement for the B gap? Ive had a look online but it only mentions no turbulence - which I am gathering is touching.
Sram have a bgap tool for sopecific cassette/rear mech combos.
Road would be a set measurement ?
Cheers
I just checked the manual for the RX815 RD and you are right, it is very unspecific (the latest DI2 road RD all come with a bgab tool). So I would gues you are fine if everything shifts well and the rear deraileurs pulley wheels have enough space towards the cassette.
Chain length is wrap around big-big, then add two links (or 1 inch). For B-tension, I go for as little as I can get away with. That means adjusting it such that it just stops making a grinding noise when shifting from second largest cog to the largest, then add another half a turn.
Sent from my moto g power (2021) using Tapatalk
