Then perhaps the fitter should have done the right thing - told his client that the bike he had just bought was incompatible with his build.jlok wrote:Maybe due to past injuries causing inflexible back, maybe short arms, maybe short torso and long neck.ms6073 wrote: ↑Tue Oct 04, 2022 11:12 pmStill trying to understand how someone who is 182 cm tall, with a 184 'wingspan', and 84 cm inseam needs an 8 cm stem?LekkerBraai wrote: Just plugged your body measurements into Trek’s size tool. According to them you should be on a 60, not a 58. Although the top tube is longer, the reach is only 3mm extra but the 20mm extra stack would put the bars where you need them to be relative to the saddle.
